BT.com
Wishlist
Samsung S22C300H 21.5" Full HD LED Monitor HDMI VGA
Delivery
Standard Due date unavailable
How do you like to watch movies? Do you like lying down on the couch? Sitting in your favourite chair? Cooking or exercising? Whether you're standing, sitting or lying down, Samsung Magic Angle makes sure that the movie always takes centre stage and that you're always comfortable. This means, thanks to the 5-mode angle management, that whatever angle you watch your Samsung monitor, you will enjoy a full visual experience with amazing picture clarity. So, start seeing your favourite movies and other multimedia in total comfort and without limitations thanks to Magic Angle.
Samsung S22C300H - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class C
Aspect Ratio
Widescreen
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Transparent red
51 cm x 19.5 cm x 39.8 cm
2.9 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Display Type
Energy Class
Class C
Diagonal Size
21.5"
Aspect Ratio
Widescreen
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, power off timer, MagicTune, MagicAngle, Mega Dynamic Contrast Ratio, Eco Saving
Transparent red
51 cm x 19.5 cm x 39.8 cm - with stand
2.9 kg
VGA ¦ HDMI
Mechanical
Tilt
1 x VGA cable
Power Supply
External
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Samsung MultiScreen
Apple MacOS, Windows 8
Dimensions & Weight Details
With stand - width: 51 cm - depth: 19.5 cm - height: 39.8 cm - weight: 2.9 kg , Without stand - width: 51 cm - depth: 5.3 cm - height: 31.9 cm - weight: 2.6 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Scroll to top
