Click to visit BT.com
BT.com
Wishlist
Samsung S22B300BH 21.5" Widescreen LED Monitor Full HD 5ms HDMI VGA Gloss Black
Quicklinx: 8484WS00
Mfr#: LS22B300HS/EN
Essential accessories
Discover greater viewing comfort and energy efficiency with the Samsung S22B300H Series 3 LED Monitor. Thanks to Magic Angle technology, you can enjoy comfortable viewing from an even larger range of angles, so you can watch TV sitting, standing, or lying down. The monitor also lets you reduce bills and environmental impact. Eco Saving adjusts brightness according to your needs, with three different energy-saving modes to choose from. It's easy to find the most comfortable setting for great viewing that is also better for your finances and the environment.
Samsung S22B300H - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Brightness
250 cd/m2
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Black, high gloss
51.2 cm x 19.7 cm x 38.5 cm - with stand
3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified , EPEAT Gold
Display Type
Diagonal Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Brightness
250 cd/m2
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicColor, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio
Black, high gloss
3 kg
VGA , HDMI
Mechanical
Tilt
1 x VGA cable
Power Supply
External
AC 120/230 V ( 50/60 Hz )
30 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 51.2 cm - depth: 19.7 cm - height: 38.5 cm - weight: 3 kg , Without stand - width: 51.2 cm - depth: 5.3 cm - height: 31.1 cm - weight: 2.7 kg
EPEAT Compliant
EPEAT Gold
