BT.com
Wishlist
Samsung S19E450MW 19" 1440x900 5ms VGA DVI LED Monitor
Delivery
Standard Due date unavailable
The SE450 Series provides an environmentally-friendly, user-friendly and budget-friendly yet high-quality desktop monitor solution for your business. The features of this 19" monitor include a simple and easy-to-use design, fully-adjustable stand, matte bezel with clearly-labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
Samsung SE450 Series S19E450MW - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
43.94 cm x 21 cm x 32.32 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
TUV, C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, TCO Displays, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
3 years warranty
Display Type
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
160
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus, 72% (NTSC 1976) colour gamut
43.94 cm x 21 cm x 32.32 cm - with stand
4.2 kg
Audio
Speakers
VGA , DVI , Headphones , Audio line-in
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
100 mm
Flat Panel Mount Interface
100 x 100 mm
PVC free
1 x VGA cable , 1 x audio cable
AC 120/230 V
15 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.005 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 43.94 cm - depth: 21 cm - height: 32.32 cm - weight: 4.2 kg , Without stand - width: 43.94 cm - depth: 5.57 cm - height: 28.99 cm - weight: 2.71 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
Scroll to top
