BT.com
Wishlist
Samsung S19E200NW 19" 1440x900 5ms VGA LED Monitor
Delivery
Standard Due date unavailable
The SE200 Series provides an environmentally friendly, user friendly and budget friendly desktop monitor solution for your business. A simple and easy to use design, a matte bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel make this monitor a perfect value for everyday tasks.
Samsung SE200 Series S19E200NW - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
43.94 cm x 17 cm x 37.36 cm
3.01 kg
Environmental Standards
ENERGY STAR Qualified
C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, PSB, AS/NZS 3548, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012
3 years warranty
Display Type
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
160
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, 72% (NTSC 1976) colour gamut
43.94 cm x 17 cm x 37.36 cm - with stand
3.01 kg
VGA
Mechanical
Tilt
Tilt Angle
-1/+20
Flat Panel Mount Interface
100 x 100 mm
PVC free
1 x VGA cable
AC 120/230 V
15 Watt
Power Consumption Stand by
0.1 Watt
Power Consumption Sleep
0.1 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 43.94 cm - depth: 17 cm - height: 37.36 cm - weight: 3.01 kg , Without stand - width: 43.94 cm - depth: 7.69 cm - height: 28.99 cm - weight: 2.72 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
Scroll to top
