BT.com
Wishlist
Samsung S19E200BW 18.9" 1440x900 5ms VGA DVI LED Monitor
With low glare commerical grade TN panel!
Delivery
Standard Due date unavailable
Clear picture quality with fast response time
  • Fast 5 ms Response Time: See even fast on-screen motion clearly and smoothly with less motion blur, judder or ghosting.
  • Full HD Resolution: Provides clean and crisp picture quality in 1920 x 1080 resolution so you can see all of your content clearly
Easy on the eyes for a more comfortable viewing experience
  • Eye Saver Mode: Unlike other colours emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimises your viewing comfort by smartly reducing blue light emissions at the touch of a button.
  • Flicker Free: Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Save energy with energy-efficient features
  • SMART Eco Saving: The SE200 reduces power consumption by 10% without a noticeable loss in picture quality thanks to eco-saving technology that automatically adjusts the brightness of the screen’s black sections while simultaneously adjusting the RGB gain values.
  • Off Timer Plus: The SE200 offers an Off Timer setting that automatically turns off your monitor after a pre-set time, and an Eco Timer setting that turns off your monitor after a pre-set period of inactivity, reducing energy consumption.
Eco-friendly materials with Intertek Green Leaf certification
  • Recycled Plastics: All Samsung business monitors are made of 30% recycled plastics. -
  • PVC Free: Monitor mechanisms and circuits are constructed without PVC* making for an eco-friendly device, lessening environmental impact.
  • Accessory Packaging: Samsung has reduced the LDPE** in accessory packaging from 100% to 80% by using bio-friendly Sugar cane (20%) as an alternative manufacturing material. Samsung packaging is now Vinçotte-certified.
  • Some cabling contains PVC. ** LDPE (Low-Density Polyethylene): A thermoplastic made from the monomer ethylene.
Samsung SE200 Series S19E200BW - LED monitor - 18.9"
LED-backlit LCD monitor - 18.9"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
43.94 cm x 17 cm x 37.36 cm
3.01 kg
Environmental Standards
ENERGY STAR Qualified
EN55022, EN55024, FCC Part 15 B, AS/NZS 3548, EN 60950-1, cULus, GB 9254-2008, K60950-1, KCC KN22, KCC KN24, UL60950-1, GB 4943-2011, GB 17625.1-2012, IEC60950-1
3 years warranty
Display Type
Diagonal Size
18.9"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, power off timer, MagicAngle, 72% NTSC colour gamut, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode
43.94 cm x 17 cm x 37.36 cm - with stand
3.01 kg
VGA , DVI
Mechanical
Tilt
Tilt Angle
-1/+20
Flat Panel Mount Interface
100 x 100 mm
PVC free
1 x VGA cable
AC 120/230 V
15 Watt
Power Consumption Stand by
0.1 Watt
Power Consumption Sleep
0.1 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 43.94 cm - depth: 17 cm - height: 37.36 cm - weight: 3.01 kg , Without stand - width: 43.94 cm - depth: 7.69 cm - height: 28.99 cm - weight: 2.72 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
10 °C
10 - 80% (non-condensing)
Scroll to top
