BT.com
Wishlist
Samsung S19B150N 18.5 WIDE LED 1366 X 768 VGA Widescreen
Delivery
Standard Due date unavailable
Discover a more vivid and dramatic viewing experience combined with great energy efficiency. The Samsung SA300 LED Monitor features a 5000000:1 Mega Dynamic Contrast Ratio, delivering a more dramatic and vibrant picture. With Eco Saving – including energy-efficient brightness adjustment and three different energy saving modes, you can keep your bills down as well as minimise the impact on the environment. Its stylish design also means that the SA300 looks great in any surroundings.
Samsung S19B150N - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
High glossy black
44.5 cm x 17.7 cm x 34.8 cm
2.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Display Type
Diagonal Size
18.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
81 kHz
Video Bandwidth
95 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Sync on Green, power off timer, MagicTune, MagicColor, MagicBright 3, Mega Dynamic Contrast Ratio
High glossy black
44.5 cm x 17.7 cm x 34.8 cm - with stand
2.1 kg
VGA
Mechanical
Tilt
Tilt Angle
-1/+20
1 x VGA cable
Power Supply
External
AC 120/230 V ( 50/60 Hz )
20 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Included Software
Samsung MultiScreen
Dimensions & Weight Details
With stand - width: 44.5 cm - depth: 17.7 cm - height: 34.8 cm - weight: 2.1 kg , Without stand - width: 44.5 cm - depth: 5.3 cm - height: 27.3 cm
EPEAT Compliant
EPEAT Gold
10 °C
10 - 80% (non-condensing)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great Little Monitor
Reviewed by Ian Rankin on 30/10/2012
I am well pleased with this. Picture is sharp and colours are rich and no dead pixels. An added bonus is the touch sensitive controls instead of buttons. I didn't even know it had them before I bought it.
I also got this for a bargain price as it was used. But it arrived in perfect condition.
Scroll to top
