Click to visit BT.com
BT.com
Wishlist
Samsung S19A450BR 19" LED Display - 1280 X 1024 - VGA - DIG - Height Adjustable
Quicklinx: 7TTYWS00
Mfr#: LS19A450BRT/EN
Essential accessories
Optimise your viewing and your energy consumption with an elegant and functional Samsung SA450 business monitor. You can customise screen tilt, perspective and height to fit your needs and work in greater comfort. Energy-efficient, lightweight design allows you to minimise financial and environmental costs as well as making the monitor easier to install and transport. There's no need to waste energy when it's not in use, either, when you use Adaptor On Off instead of a standby mode. You can even save space and clutter with the detachable adaptor and cable arrangement features.
Samsung S19A450BR - LED monitor - 19"
LED-backlit LCD monitor - 19"
Native Resolution
1280 x 1024
Brightness
250 cd/m²
Contrast Ratio
5000000:1 / 1000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, tilt
Matte black
41.3 cm x 20.1 cm x 40.1 cm - with stand
4.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Display Type
Diagonal Size
19"
Native Resolution
1280 x 1024
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
85
Vertical Viewing Angle
80
Backlight Technology
LED backlight
Power off timer, MagicColor, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio
Matte black
4.6 kg
VGA , DVI-D
Mechanical
Height, tilt
Height Adjustment
100 mm
Flat Panel Mount Interface
100 x 100 mm
Power Supply
External
Power Consumption Stand by / Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 41.3 cm - depth: 20.1 cm - height: 40.1 cm - weight: 4.6 kg , Without stand - width: 41.3 cm - depth: 5 cm - height: 34.8 cm
EPEAT Compliant
EPEAT Gold
