BT.com
Wishlist
Samsung QM85D-BR 85" 3840 x 2160 VGA DVI HDMI Large Format Display
Samsung QM85D-BR 85" 3840 x 2160...
£12,556.77
£12,556.77
Add to wishlist
Delivery
Standard Due date unavailable
This advanced display is ready to deliver your business message in realistic detail. You have a possibility to enhance efficiency by displaying content from several Full HD screens on a single UHD display and to increase its usability with flexible configurations.
Samsung QM85E-BR QMD Series - 85" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
85"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Motion Enhancement Technology
120Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, Auto Source Switching & Recovery
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class C
495 Watt
Power Consumption (On mode)
369 W
Energy Consumption per Year
539 kWh
194.9 cm x 9.51 cm x 113 cm
83 kg
Energy Class
Class C
495 Watt
369 W
539 kWh
Diagonal Class
85"
Commercial Use
Combined with
Touchscreen
Series
QMD Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Protection
Protection glass
Dimensions
Without stand
194.9 cm
9.51 cm
113 cm
83 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
120Hz Refresh Rate
LED backlight
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Brightness
430 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
10
Response Time
6 ms
Backlight Life
50,000 hour(s)
Commercial Features
Pivot, Multiple Display Control (MDC), d-LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
30 Watt
Speakers
2 x main channel speaker - built-in - 15 Watt
Connector Type
3 x HDMI input , DVI-D input , VGA input , Audio line-out , Audio line-in , 3 x DisplayPort input , Multiple Display Control
DisplayPort cable
Plug and Play, DDC/CI, EMC Class A
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
209.6 cm
Depth (Shipping)
52.2 cm
Height (Shipping)
131.3 cm
Weight (Shipping)
99 kg
10 - 80%
Scroll to top
