BT.com
Wishlist
Samsung QM85D 85" 3840x2160 VGA DVI HDMI DisplayPort LED Large Format Display
Samsung QM85D 85" 3840x2160 VGA DVI...
£10,841.35
20 in stock
£10,841.35
Add to wishlist
Delivery
Standard 1-3 working days
With stunning 4K quality 85" UHD QM-D Series display provides high pixel density, fine detail and exceptional stopping power. You can even display Full HD content in 4K via UHD upscaling. Whether it's in your retail space, corporate boardroom or public area, you can make every impression count.
Samsung QM85D QMD Series - 85" LED display
LED-backlit LCD flat panel display
Diagonal Class
85"
Commercial Use
Yes - digital signage / hospitality
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Wall Components Qty
225
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Auto Source Switching & Recovery
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Energy Class
Class B
495 Watt
Power Consumption (On mode)
375 W
Energy Consumption per Year
548 kWh
190.34 cm x 10.51 cm x 109.05 cm
55.5 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
495 Watt
375 W
548 kWh
Diagonal Class
85"
Commercial Use
Series
QMD Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
225
Dimensions
Without stand
190.34 cm
10.51 cm
109.05 cm
55.5 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.1625 x 0.1625mm
Response Time
6 ms
Commercial Features
Pivot, Multiple Display Control (MDC), MagicInfo, LED BLU, Optional Touch Overlay, Certified for 16/7 Continuous Operation
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
30 Watt
Speakers
2 x main channel speaker - built-in - 15 Watt
Connector Type
3 x HDMI input , DVI-D input , VGA input , Audio line-out , Serial input , Serial output , Audio line-in , Multiple Display Control , Remote control/ambient sensor input , Remote control output , USB 2.0 , 3 x DisplayPort input
DisplayPort cable
Plug and Play, DDC/CI, EMC Class A
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
205 cm
Depth (Shipping)
47.2 cm
Height (Shipping)
126.5 cm
Weight (Shipping)
71.4 kg
10 - 80%
Scroll to top
