BT.com
Wishlist
Samsung QM105D 105" 5120x2160 VGA DVI HDMI DisplayPort LED Large Format Display
Delivery
Standard Due date unavailable
With the ultra-high-definition (UHD) technology, businesses can convey more impactful messaging and information with ultra-crisp detail. Samsung 105" QMD Series offers the ultimate picture quality on an immersive super-large format, 21:9 screen. This premium display's commercial-grade glossy 5K UHD Glare panels ensure reliable operation, 16/7. Impactful QM105D SMART Signage is perfectly suited for businesses that rely on detailed content or want to enhance their brand with vibrant images.
Samsung QM105D QMD Series - 105" LED display
LED-backlit LCD flat panel display
Diagonal Class
105"
Commercial Use
Yes - digital signage / hospitality
Resolution
5120 x 2160
Display Format
5K UHD (2160p)
Motion Enhancement Technology
120Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
21:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Auto Source Switching & Recovery
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Energy Class
Class D
990 Watt
Power Consumption (On mode)
715 W
Energy Consumption per Year
1044 kWh
248.97 cm x 10.51 cm x 107.32 cm
108.8 kg
Energy Class
Class D
990 Watt
715 W
1044 kWh
Diagonal Class
105"
Commercial Use
Series
QMD Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
248.97 cm
10.51 cm
107.32 cm
108.8 kg
Display
Resolution
5120 x 2160
Display Format
5K UHD (2160p)
Image Aspect Ratio
21:9
120Hz Refresh Rate
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
50000:1
Brightness
500 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.1595 x 0.4785mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), MagicInfo, LED BLU, Certified for 16/7 Continuous Operation
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
1600 x 600 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
30 Watt
Speakers
2 x main channel speaker - built-in - 15 Watt
Connector Type
Remote control/ambient sensor input , 3 x HDMI input , 3 x DisplayPort input , Multiple Display Control , Remote control output , Serial input , Serial output , VGA input , Audio line-in , Audio line-out , USB 2.0 , DVI-D input
Batteries
DisplayPort cable
Plug and Play, DDC/CI, EMC Class A
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
Width (Shipping)
270 cm
Depth (Shipping)
80 cm
Height (Shipping)
136 cm
Weight (Shipping)
157.7 kg
10 - 80%
Scroll to top
