BT.com
Wishlist
Samsung PS51F4500 51 inch Plasma TV HD Ready
Delivery
Standard Due date unavailable
With the Samsung F4500 Series 4 Plasma TV, superior viewing is a reality for everyone. Thanks to Clean View technology, digital noise is filtered out to give you an enhanced picture. Meanwhile, the new filter and panel structure stops layered images, dual images and blurring, as well as giving clear images from a wide range of viewpoints. Using advanced subfield motion technology, your F4500 also delivers smoother motion - even for fast-moving images. And, with ConnectShare Movie, you can access all your content on USB storage.
Filtering noise for added TV viewing pleasure
Experience crystal-clear TV viewing with Samsung's Clean View. When Clean View's auto noise-removal technology is applied, it removes digital noise that is seen on the screen, enhancing the picture quality. Sit back, relax and watch TV with the best clarity.
Clear Image Panel
The Samsung Plasma+1 TV uses a new filter and panel structure to eliminate layered images and produce clear images from almost every angle. This also eliminates the production of dual images and blurring typically found with glass.
Bringing a full multimedia experience into your living room
With High Definition Multimedia Interface (HDMI) inputs, the Samsung TV will transform your living room into a multimedia entertainment centre. HDMI provides high-speed transmission of high definition digital data from multiple devices straight into your TV.
Smoother images for greater clarity
Using the latest in subfield motion technology, Samsung Plasma TV flashes a single image up to 600 times a second. The result is smoother images with unprecedented picture quality, no matter how fast the images are moving.
Watch movies from your USB
With ConnectShare Movie, simply plug your USB memory drive or HDD into the TV and instantaneously enjoy movies, photos or music. Now, you can experience a wide variety of content in the comfort of your living room on your TV.
Samsung PS51F4500 4 Series - 51" plasma TV
Plasma TV
Energy Class
Class A
Diagonal Class
51"
118.52 cm x 23.5 cm x 78.3 cm
19.1 kg
Resolution
1024 x 768
Motion Enhancement Technology
600Hz Subfield Motion
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
HDCP Compatible
Digital TV Tuner
DVB-C, DVB-T
Multi-channel Preview
Picture-in-picture (PIP)
Speaker System
2 speakers
Sound Effects
DTS Studio Sound, DTS Premium Audio 5.1
USB Port
Yes , 1 ports
Remote Control
Standard remote
AC 120/230 V ( 50/60 Hz )
1 year warranty
Plasma TV
Energy Class
Class A
Diagonal Class
51"
Series
4 Series
Sensors
Eco Sensor
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Modes
Game mode
Timer Functions
Sleep, wake
Protection
Screen burn protection
Dimensions
With stand
118.52 cm
23.5 cm
78.3 cm
19.1 kg
Enclosure Colour
Display
Resolution
1024 x 768
Cinema Smooth Technology, HyperReal Engine, Wide Color Enhancer Plus, Online Instruction Manual, Clear Image Panel, Black Optimizer, Digital Clean View
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
400 x 400 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T
Video Features
Teletext
Electronic Programme Guide
Digital EPG
Media Player
USB Port
Yes , 1 ports
Remote Control
Standard remote
Remote Control Model
Samsung TM1240
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
Down-firing Speaker, Auto Volume Leveller (AVL)
Speakers
2 x main channel speaker - built-in - 10 Watt
Driver Details
Main channel speaker: 1 x full-range driver
Network & Internet Multimedia
Connect & Share
ConnectShare Movie
Connector Type
Composite video / component video input , Audio line-in , Digital audio output (optical) , 2 x HDMI input , USB
Power supply
Nominal Voltage
Power Consumption Stand by
0.3 Watt
Auto On/Off
Limited warranty - parts and labour - 1 year - on-site
Dimensions & Weight Details
Panel without stand - 118.52 cm x 5.57 cm x 70.21 cm x 17.7 kg , Panel with stand - 118.52 cm x 23.5 cm x 78.3 cm x 19.1 kg
Width (Shipping)
129.2 cm
Depth (Shipping)
33 cm
Height (Shipping)
81 cm
Weight (Shipping)
25.2 kg
Scroll to top
