BT.com
Wishlist
Samsung ProXpress M4070FR Mono Laser Multifunction Printer
Delivery
Standard Due date unavailable
The robust ProXpress M4070FR features print speeds of up to 42 ppm. Powered by a Cortex-A5 core processor, it delivers unsurpassed performance for business applications. And with a Duplexing Automatic Document Feeder (DADF) able to process pages at up to 24 ipm, scan and copy jobs are a breeze. High performance coupled with ease-of-use enables businesses to accelerate document and image processing for increased efficiency.
With 4-in-1 capability including print, copy, scan and fax and built-in duplex printing you can be sure the ProXpress M4070FR provides your business the versatility you need to stay competitive.
The ProXpress M4070FR employs an all-in-one toner system, meaning that the toner and imaging unit are integrated into a single cartridge, for easy changing and easy stocking. It also offers several different cartridges options from standard-yield laser toner cartridges that typically yield 3,000 standard pages to ultra-high yield laser toner cartridges that can yield up to 15,000 standard pages, which meets every business's needs for reducing spending. Whether you are looking for a lower up-front cost, or a lower overall cost per page, there's a cartridge suitable for your needs.
What's in the box
  • Samsung ProXpress M4070FR
  • Cartridge - black
Samsung ProXpress M4070FR - multifunction printer (B/W)
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
100000 impressions
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, thin paper, thick paper
Standard Media Capacity
300 sheets
Max Media Capacity
820 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, scan to network
46.9 cm x 44.43 cm x 48.21 cm
17.07 kg
Fax Type
Plain paper
Printing Technology
Laser - monochrome
100000 impressions
Display
4 lines
Standard Memory
256 MB
Max Supported Memory
512 MB
Hard Disk Drive
4 GB
Copying
Max Copying Speed
Up to 40 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, IBM Proprinter, SPL, PDF
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
Fax Machine Features
Speed Dialing
200 station(s)
Broadcast Transmission
209 stations
Delayed Transmission
Fax forwarding, automatic redialing
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
300 sheets
Max Media Capacity
820 sheets
50 sheets
150 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Paper cassette - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 40 ppm (A4) - B/W , Printing: up to 42 ppm (Letter A) - B/W , Copying: up to 40 ppm (A4) - B/W , Copying: up to 42 ppm (Letter A) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB - 4 pin USB Type A
Operating System Support
MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.5 - 10.8
700 Watt
Power Consumption Standby
10 Watt
Power Consumption Sleep
1.1 Watt
First Copy Out Time B/W
10 sec
Consumables Included
1 x Cartridge (black) - up to 3000 pages
ISO/IEC 19752
46.9 cm
44.43 cm
48.21 cm
17.07 kg
Sound Emission
26 dBA (idle) / 58 dBA (operating)
Scroll to top
