BT.com
Wishlist
Samsung ProXpress C2670FW Colour Laser Multifunction Printer
Delivery
Standard Due date unavailable
Discover printing solutions designed to ignite your productivity. The ProXpress C2670FW A4 Color Multifunction Laser Printer features Near Field Communication (NFC), so you can tap, print and go. An intuitive touch screen provides ease of use, while print, copy, scan and fax capability delivers versatility.
Samsung ProXpress C2670FW - multifunction printer (colour)
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
60000 pages
Max Copying Speed
Up to 26 ppm (mono) / up to 26 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock, glossy paper, cotton paper, punched paper, archive paper
Standard Media Capacity
300 sheets
Max Media Capacity
820 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder
46.9 cm x 45.25 cm x 50.43 cm
26.62 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
60000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
Standard Memory
512 MB
Max Supported Memory
1 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PostScript 3, SPLC, PDF 1.7, PCL 6C, PCL 5ce
Automatic Duplexing
First Print Out Time B/W
17 sec
First Print Out Time Colour
17 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Fax forwarding, multi-send, delayed sending
Document & Media Handling
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
300 sheets
Max Media Capacity
820 sheets
50 sheets
150 sheets
ADF - 50 sheets , Paper cassette - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 26 ppm (A4) - B/W , Printing: up to 27 ppm (Letter A) - B/W , Printing: up to 26 ppm (A4) - colour , Printing: up to 27 ppm (Letter A) - colour , Copying: up to 26 ppm (A4) - B/W , Copying: up to 27 ppm (Letter A) - B/W , Copying: up to 26 ppm (A4) - colour , Copying: up to 27 ppm (Letter A) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Operating System Support
MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.4 - 10.8
500 Watt
Power Consumption Standby
18 Watt
Power Consumption Sleep
2.48 Watt
First Copy Out Time B/W
19 sec
First Copy Out Time Colour
19 sec
4 GB SD memory card
Consumables Included
1 x Cartridge (black) - up to 2000 pages , 1 x Cartridge (cyan) - up to 1500 pages , 1 x Cartridge (magenta) - up to 1500 pages , 1 x Cartridge (yellow) - up to 1500 pages
ENERGY STAR Certified
46.9 cm
45.25 cm
50.43 cm
26.62 kg
Sound Emission
37 dBA (idle) / 56 dBA (operating)
Scroll to top
