BT.com
Wishlist
Samsung Protective Cover+ for Galaxy S4 Light Blue
Samsung Protective Cover+ for...
£14.83
£14.83
Add to wishlist
Delivery
Standard Due date unavailable
The Samsung Galaxy S4 Protective Cover Plus case is a precision designed mobile phone case that protects the device without sacrificing style. Galaxy cases also feature one of the sleekest android phone case designs, allowing for both function and fashion. The cover is available in a range of stylish covers. Some mobile phone cases can restrict the phones functionality, however, each Samsung phone case is designed to allow easy access to all ports and buttons. Samsung cases are built to the specifications of the phone to insure an exact fit and maintain the full functionality of the phone. Each of the phone cases slips gently over the phone providing it with a hard shell that protects against bumps and drops. The cover installation is effortless and the can be done in under a minute.
Thermoplastic construction provides protection against shocks and drops. Manufactured from injection moulded thermoplastic, the Galaxy S4 protective case is easy to apply and remove, but also extremely protective. The case offers outstanding protection against impacts, so your phone is protected whether it's in a bag or pocket, or if you happen to accidentally drop it.
High polymer coating prevents dust and fingerprint build-up. The outside of the case has a special high polymer coating that gives the case a classy glossy look, while also helping to resist dust and grease. This keeps your case looking newer for longer, and ensures there's no unhygienic build-up of grime around the openings.
Gloss finish adds style to your phone complementing the slim line profile of the Galaxy S4 protective case is the piano pink gloss finish which not only helps to reduce fingerprints and other marks on the case but also helps make the phone look sleek and stylish.
Made for Samsung Galaxy S4
Designed specifically for the Samsung Galaxy S4, this case offers a perfect fit for your device. With cut-outs for all the ports, buttons and camera, you don't have to worry about losing functionality while using this case.
Features:
  • Protects device from impact, scratches and dirt build-up
  • Custom made to allow easy access to all ports and buttons
  • Easy to install
  • Available in a variety of colours
  • Cover is scratch resistant
Samsung Protective Cover+ EF-PI950B back cover for mobile phone
Back cover for mobile phone
7.38 cm x 1.39 cm x 14.06 cm
26.4 g
Light blue
Galaxy S4
7.38 cm
1.39 cm
14.06 cm
26.4 g
Light blue
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Camera lens cutout, port cut-outs
Samsung Galaxy S4
Scroll to top
