BT.com
Wishlist
Samsung PE46C 46" 1920x1080 8ms DVI-D HDMI DisplayPort E-LED System on Chip Large Format Display
Delivery
Standard Due date unavailable
Convey the right message in a highly efficient, controllable, and cost-effective manner with Samsung PE series premium signage displays. Start capturing your audience immediately to increase your business performance. Designed for companies that require a superior digital signage solution in high-traffic areas which do not compromise on quality and performance, Samsung PE series premium signage displays enable continuous, high-quality content presentation in any environment. Equipped with Samsung's powerful and exclusive SSSP technology using dual-core CPU, and a combination of media player and integrated display solution, MagicInfo premium S player, the Samsung PE series can deliver multiple types of content seamlessly to your audience. Watch your display management productivity go up as your total cost of ownership goes down with this all-in-one display.
Samsung PE46C PE Series - 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform
Remote Control
Standard remote
Voltage
Energy Class
Class B
187 Watt
Power Consumption (On mode)
110 W
Energy Consumption per Year
161 kWh
105.45 cm x 3.51 cm x 60.85 cm
16.4 kg
Energy Class
Class B
187 Watt
110 W
161 kWh
Diagonal Class
46"
Commercial Use
Series
PE Series
TV Tuner
No tuner
Video Interface
PC Interface
HDCP Compatible
Dimensions
Without stand
105.45 cm
3.51 cm
60.85 cm
16.4 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.17675 x 0.53025mm
Response Time
8 ms
Commercial Features
Certified for 24/7 Continuous Operation, MagicInfo, Dual-Core processor
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , DisplayPort , Composite video / component video input , HDMI input , Audio line-in , Audio line-out
VGA cable
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
1 Watt
Width (Shipping)
114.1 cm
Depth (Shipping)
14 cm
Height (Shipping)
71.9 cm
Weight (Shipping)
20.1 kg
10 - 80%
Scroll to top
