BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Samsung Optical Smart Hub
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
External DVD Writer Drive, with Wireless Streaming to iOS and Android, NAS Controller and Smart Backup
Samsungs new Rewriter Drive - Experience Optical SMART Hub Connect wirelessly from external storage devices to your tablet, smartphone and Smart TVs
CD/DVD Streaming
How to entertain your kids during a long road trip? Through wireless connection, they can enjoy their programs on a tablet by streaming from SMART Hub.
Smart Backup
With Samsung's mobile App, you can burn a disc quickly.
File Manager
Did you forget to make copies for your client? Just connect a USB memory or external HDD to SMART Hub to become a small network for sharing documents.
DLNA (Digital Living Network Alliance)
Watch your media files s streamed to your TV, Smartphone or a Tablet PC through a wireless connection using optical SMART Hub.
NAS (Network Attached Storage)
Has your smartphone reached capacity? Here is the solution. Back up your photos through the SE-208BW. Just connect to SMART Hub using mobile App. Capacity is no longer an issue.
SMART Hub App
Mobile App supports Android and iOS. You can find the App on Android market and App store for your smart life.
Wireless Specification
  • Compliance Standard - IEEE802.11 b/ g (802.11ncan be used)
  • Frequency range - 2.412 ~ 2.472 MHz
  • Access method - CSMA / CA
  • Data transfer method - DDSS, OFDM, Half Duplex
  • Data transfer speed (max) - 802.11b - 11 Mbps, 802.11g - 54 Mbps
  • WDS - Supported
  • Encryption - WEP, WPA - PSK, WPA2 - PSK, MIXED
WAN
  • Acess method
  • ISP protocols supported
  • Interface connector type
Smart Backup
  • USB
  • ODD
CDDA
  • Supported with the iOS / Android Optical SMART Hub app only
DVD Playback
FTP
  • Supported (Using the FTP client software is recommended)
iSCSI
  • Supported
Samba
  • Supported
Optical Drive Specification
  • Drive Type - DVD writer
  • Enclosure Type - External
  • Loading Type - Tray
  • Interface - USB 2.0
  • Drive Mounting - Horizontal
  • Buffer Memory - 1.0MB
Data Transfer Rate (Write, Read)
  • DVD±R - 8x,8x
  • DVD±R Dual Layer - 6x,8x
  • VD+RW - 8x,8x
  • DVD-RW - 6x,8x
  • DVD-RAM - 5x,5x
  • DVD-ROM - N/A,8x
  • CD-ROM - N/A,24x
  • CD-R - 24x,24x
  • CD-RW - 24x,24x
Performance Features
  • Average Access Time: CD-ROM - 190ms / DVD-ROM - 190ms
Product Weights & Dimensions
  • 150mm x 25mm x 198 mm, 0.43 (Kg)
Scroll to top
