BT.com
Wishlist
Samsung OM55D-W 55" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Samsung OM55D-W 55" 1920x1080 VGA...
Free delivery
£4,396.26
Free delivery
£4,396.26
Add to wishlist
Delivery
Standard Due date unavailable
Draw more visitors to your retail business by effectively delivering promotional messaging with excellent visibility. OMD series SMART Signage features high brightness and contrast ratio for superb visibility in various lighting environments. Even customers who are wearing polarized sunglasses can view messages with outstanding clarity and brightness, without the display-blindness effect typically experienced with LCD displays.
Samsung OM55D-W 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class D
495 Watt
Power Consumption (On mode)
297 W
Energy Consumption per Year
434 kWh
122.74 cm x 13.95 cm x 69.82 cm
24 kg
Energy Class
Class D
495 Watt
297 W
434 kWh
Diagonal Class
55"
Commercial Use
TV Tuner
No tuner
Sensors
Temperature sensor, brightness sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode
100
Dimensions
Without stand
122.74 cm
13.95 cm
69.82 cm
24 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
5000:1
Brightness
2500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6 ms
Commercial Features
Button lock
Multiple Display Control (MDC), Lamp Error Detection, digital daisy chain, MagicInfo, anti-image retention, Smart Scheduling, MagicInfo Player-S2
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , DisplayPort input , 2 x HDMI , Composite video / component video input , Audio line-in , DisplayPort output , Audio line-out
VGA cable
Plug and Play, UL, TUV, VCCI, C-Tick, BSMI, GOST, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, EN 60950-1, KCC, BSMI CNS 13438, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, GB4943.1-2011, GB 17625.1-2012, IEC60950-1
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
133.5 cm
Depth (Shipping)
26.5 cm
Height (Shipping)
80.8 cm
Weight (Shipping)
30 kg
30 °C
10 - 80%
Scroll to top
