BT.com
Wishlist
Samsung OM46D-K 46 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Samsung OM46D-K 46 1920x1080 VGA...
£2,797.62
£2,797.62
Add to wishlist
Delivery
Standard Due date unavailable
Samsung OMD-K High Brightness Display provides easily readable text and bright graphics in high ambient light environments and outdoor applications, along with all-weather durability when installed in a customized housing. And with the SMART Signage Platform, you can manage your content without external devices.
Samsung OM46D-K 46" LED display
LED-backlit LCD flat panel display
Energy Class
Class D
395 Watt
Power Consumption (On mode)
216 W
Energy Consumption per Year
315 kWh
Diagonal Class
46"
Commercial Use
Yes - digital signage
TV Tuner
No tuner
Sensors
Temperature sensor, brightness sensor
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
Modes
Portrait mode
Video Wall Components Qty
100
Dimensions
Without stand
103.59 cm
14.29 cm
59.05 cm
18.7 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LCD Backlight Technology
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
5000:1
Brightness
2500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6 ms
Commercial Features
Button lock
Multiple Display Control (MDC), Lamp Error Detection, digital daisy chain, MagicInfo, anti-image retention, Smart Scheduling, MagicInfo Player-S2
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Standard remote
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , DisplayPort input , 2 x HDMI , Composite video / component video input , Audio line-in , DisplayPort output , Audio line-out
VGA cable
UL, TUV, VCCI, C-Tick, BSMI, GOST, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, EN 60950-1, KCC, BSMI CNS 13438, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, GB4943.1-2011, GB 17625.1-2012, IEC60950-1
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
112.3 cm
Depth (Shipping)
23.6 cm
Height (Shipping)
68.6 cm
Weight (Shipping)
24.2 kg
30 °C
10 - 80%
Scroll to top
