BT.com
Wishlist
Samsung OM24E 24" 1920x1080 VGA HDMI S-PVA Large Format Display
Samsung OM24E 24" 1920x1080 VGA...
£1,100.14
£1,100.14
Add to wishlist
Delivery
Standard Due date unavailable
Samsung's compact, semi-outdoor signage solution provides business owners with a dynamic tool to deliver coherent messaging to prospective customers. Ideal for a window display in a retail shop, real estate agency or other service oriented business, OME displays can help increase sales by giving you another way to communicate your brand identity.
Samsung OM24E 24" Class (23.8" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
24"
Diagonal Size
23.8 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
S-VA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Auto Source Switching & Recovery, Lamp Error Detection
Voltage
Energy Class
Class D
Power Consumption (On mode)
67 W
Energy Consumption per Year
98 kWh
54.92 cm x 5.8 cm x 31.91 cm
3.5 kg
Energy Class
Class D
67 W
98 kWh
Diagonal Class
24"
Diagonal Size
23.8 in
Commercial Use
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode
Dimensions
Without stand
54.92 cm
5.8 cm
31.91 cm
3.5 kg
Display
LCD Display Technology
S-VA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
100000:1
Brightness
1500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, anti-image retention, Smart Scheduling, MagicInfo Player-S3
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm
Audio System
Built-in speaker
Connector Type
HDMI input , Audio line-in , VGA input , Audio line-out
Batteries, external brightness sensor
VGA cable
Plug and Play, TUV, GOST, NEMKO, PCBC, SASO, SIQ, CCC, PSB, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, KC, NOM-019-SCFI-1998, K60950-1, GB4943.1-2011, EN 55022
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
65.1 cm
Depth (Shipping)
13.9 cm
Height (Shipping)
39 cm
Weight (Shipping)
4.8 kg
50 °C
10 - 80%
Scroll to top
