BT.com
Wishlist
Samsung OH24E 24" 1920x1080 HDMI S-PVA Large Format Display
Samsung OH24E 24" 1920x1080 HDMI...
£1,846.34
£1,846.34
Add to wishlist
Delivery
Standard Due date unavailable
Samsung's small and versatile outdoor signage allows businesses to tap into a world of customer engagement. By showcasing compelling and entertaining content, you can monetize and leverage customer attention at ATMs, gas pumps and other locations that people encounter throughout their day.
Samsung OH24E 24" Class (23.8" viewable) LED display
LED-backlit LCD flat panel display with built-in PC
Diagonal Class
24"
Diagonal Size
23.8 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
HDCP Compatible
S-VA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, Lamp Error Detection, SMART Signage Platform 3nd Generation
Storage Drive Capacity
8 GB
USB
Remote Control
Standard remote
Voltage
Energy Class
Class D
Power Consumption (On mode)
67 W
Energy Consumption per Year
98 kWh
56.32 cm x 6.64 cm x 33.32 cm
10.6 kg
Energy Class
Class D
67 W
98 kWh
Diagonal Class
24"
Diagonal Size
23.8 in
Commercial Use
Combined with
Built-in PC
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
HDCP Compatible
Modes
Portrait mode
Design
Rugged design
Protection
Dustproof, protection glass, water-resistant
56.32 cm
6.64 cm
33.32 cm
10.6 kg
Display
LCD Display Technology
S-VA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-reflection
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
100000:1
Brightness
1500 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, anti-image retention, Smart Scheduling, Auto Brightness Control, MagicInfo Player-S3
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm
Media Player
USB Port
USB Ports Qty
1
PC Configuration
ARM Cortex-A9 Quad-Core / 1.5 GHz / 1 GB DDR3 / 8 GB Flash
8 GB
Operating System
Linux
Remote Control
Standard remote
Connector Type
HDMI input , Audio line-out , USB 2.0 , Serial input , Multiple Display Control
Batteries
TUV, C-Tick, GOST, NEMKO, PCBC, SASO, SIQ, CISPR 22, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60529 IP56, BSMI CNS 13438, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, GB 17625.1, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1998, K60950-1, KCC KN22, KCC KN24, GB4943.1-2011, EN 55022, EN 55024
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
67.8 cm
Depth (Shipping)
15.3 cm
Height (Shipping)
41.8 cm
Weight (Shipping)
12 kg
-30 °C
50 °C
10 - 80%
Scroll to top
