BT.com
Wishlist
Samsung ME75B 75" 1920x1080 4ms D-sub DVI-D HDMI RJ45 Speakers Black LED SOC Large Format Display
Free delivery
Delivery
Standard Due date unavailable
The ME75B extends Samsung's LED leadership into larger size display by offering a 75" screen size, respectively. This display offers a light weight display designed for commercial and retail customers looking to reduce energy spend and time and cost of installations. The FHD display comes equipped with a DVI-out component and easy content control through RS232C and RJ45 ports. A narrow bezel of just 21.5 mm allows customers to focus more on content, and its slim depth offers more available space for other uses.
Samsung ME75B 75" LED display
LED-backlit LCD flat panel display
Diagonal Class
75"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Energy Class
Class B
Power Consumption (On mode)
225 W
Energy Consumption per Year
329 kWh
167.82 cm x 4.99 cm x 95.87 cm
44.1 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
225 W
329 kWh
Diagonal Class
75"
Commercial Use
TV Tuner
No tuner
Video Interface
PC Interface
HDCP Compatible
Dimensions
Without stand
167.82 cm
4.99 cm
95.87 cm
44.1 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
100000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6 ms
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
Remote Control
Standard remote
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
30 Watt
Speakers
2 x main channel speaker - built-in - 15 Watt
Connector Type
HDMI input , Composite video / component video input , Audio line-in , DVI-D input , VGA input , Audio line-out , Serial input , Network , USB , DisplayPort , Serial output , DVI-D output
VGA cable
Plug and Play
Power supply
Nominal Voltage
Power Consumption Stand by / Sleep
1 Watt
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
186.3 cm
Depth (Shipping)
47.3 cm
Height (Shipping)
117.3 cm
Weight (Shipping)
69.7 kg
Scroll to top
