BT.com
Wishlist
Samsung ME65B 65"" LED 1920X1080 VGA DVI RJ45 Spkers Blk 3yr Wrty
Delivery
Standard Due date unavailable
The ME65B offers a light weight display designed for commercial and retail customers looking to reduce energy spend and time and cost of installations. The FHD display comes equipped with a DVI-out component and easy content control through RS232C and RJ45 ports. A narrow bezel of just 21.5 mm allows customers to focus more on content, and its slim depth offers more available space for other uses.
Samsung ME65B 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers
Storage Drive Capacity
32 GB
USB
Remote Control
Standard remote
180 Watt
148.05 cm x 3.35 cm x 85.55 cm
25.1 kg
Environmental Standards
ENERGY STAR Qualified
180 Watt
Diagonal Class
65"
Commercial Use
TV Tuner
No tuner
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
148.05 cm
3.35 cm
85.55 cm
25.1 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
100000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.744 x 0.744mm
Response Time
8 ms
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
PC Configuration
AMD A4-3310M Dual-Core / 2 GB DDR3 / ATI Radeon HD 6620G
32 GB
Remote Control
Standard remote
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
30 Watt
Speakers
2 x main channel speaker - built-in - 15 Watt
Connector Type
HDMI , Composite video input , Audio line-in - rear , DVI-D output , VGA input , DisplayPort , DVI-D input - rear , Serial input - rear , Network , USB 2.0 , Serial output - rear
VGA cable
ENERGY STAR Version
5.0
Power supply
Power Consumption Stand by / Sleep
1 Watt
Width (Shipping)
164.1 cm
Depth (Shipping)
22 cm
Height (Shipping)
98.8 cm
Weight (Shipping)
32.2 kg
Scroll to top
