BT.com
Wishlist
Samsung ME40C 40" 1920x1080 8ms DVI-D HDMI DisplayPort E-LED System on Chip Large Format Display
Delivery
Standard Due date unavailable
An increasing number of organizations are using large format displays (LFDs) to display their business content and to differentiate their organization from competitors. Companies need displays that offer excellent image resolution but are lighter weight and take up minimal space. The Samsung MEC series LED LFD delivers superior LED technology in a slim display without increasing energy costs. Equipped with Samsung's powerful and exclusive SSSP technology and integrated display solution, MagicInfo Premium S player, the Samsung MEC series can deliver multiple types of content seamlessly. Watch your display management productivity go up as your total cost of ownership goes down with this all-in-one display.
Samsung ME40C 40" LED display
LED-backlit LCD flat panel display with built-in PC
Diagonal Class
40"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock
Speaker System
2 speakers
Storage Drive Capacity
4 GB
USB
Remote Control
Standard remote
Voltage
Energy Class
Class C
110 Watt
Power Consumption (On mode)
90 W
Energy Consumption per Year
131 kWh
92.21 cm x 2.99 cm x 53.94 cm
10.6 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class C
110 Watt
90 W
131 kWh
Diagonal Class
40"
Commercial Use
Combined with
Built-in PC
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
92.21 cm
2.99 cm
53.94 cm
10.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Dynamic Contrast Ratio
5000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.15375 x 0.46125mm
Response Time
8 ms
Commercial Features
Button lock
Pivot, Multiple Display Control (MDC), Lamp Error Detection, digital daisy chain, MagicInfo Lite, Smart Scheduling
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
Supported Video Formats
MPEG-1, MPEG-2, AVC, H.264, VC-1
Supported Audio Formats
AC3, DTS
Supported Pictures Formats
JPG, PNG
USB Port
Yes , 1 ports
PC Configuration
ARM Cortex-A9 / 1 GHz
4 GB
Operating System
Linux
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
2 x HDMI input , Composite video / component video input , Audio line-in , DVI-D input , VGA input , Audio line-out , Serial input , Multiple Display Control , USB 2.0 , DisplayPort input , Serial output , DisplayPort output , Audio line-in
VGA cable
EN55022, FCC Part 15 B
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
AC 120/230 V ( 50/60 Hz )
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
102 cm
Depth (Shipping)
13 cm
Height (Shipping)
61.6 cm
Weight (Shipping)
12.6 kg
10 - 80% (non-condensing)
Scroll to top
