BT.com
Wishlist
Samsung MD32B 32" LED VGA DVI RJ45 Speakers Black 3 Year Warranty
Delivery
Standard Due date unavailable
With Samsung MD series LFD you can take greater control of your business communications. The combination of brilliant visuals, rich audio, and various features, ensures that updating everything from marketing material to live information is easily achieved. Moreover, this LFD delivers a cost-effective solution that's also gentle on the planet with the eco-friendly, low power consuming with LED back light solution!
Samsung MD32B 32" LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
50 Watt
73.6 cm x 9.35 cm x 43.45 cm
6.3 kg
50 Watt
Diagonal Class
32"
Commercial Use
TV Tuner
No tuner
Video Interface
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
73.6 cm
9.35 cm
43.45 cm
6.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.12125 x 0.36375mm
Response Time
8 ms
MagicInfo Lite, LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
USB Port
Remote Control
Standard remote
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
HDMI , Composite video/audio input , Audio line-in , DVI-D input , VGA input , Audio line-out , Serial input , Remote control , USB , Serial output , Component video input
VGA cable
Plug and Play
Power supply
Nominal Voltage
AC 120/230 V ( 50/60 Hz )
Power Consumption Stand by / Sleep
1 Watt
1 Watt
Width (Shipping)
82.6 cm
Depth (Shipping)
16.2 cm
Height (Shipping)
53 cm
Weight (Shipping)
8 kg
10 - 80%
Scroll to top
