BT.com
Wishlist
Samsung Mains Charger - Micro USB - for Galaxy/Nexus Smartphones
Delivery
Standard Due date unavailable
Samsung ETA0U70UBEGSTD Travel Adaptor - Compatible with Galaxy Nexus - UK Plug to Micro USB - Samsung Fastcharge technology
Samsung's quick charging technology allows you to use your Samsung devices while it is charging. This compact charger is made from the highest quality materials and to the strictest standards. The compact and durable design makes it convenient to charge your battery while at home or on the go.
Product Features
  • Compact and durable design
  • Plugs into any standard wall outlet
  • Comes with a genuine Samsung USB to MicroUSB data cable
  • Samsung's quick charging technology allows you to use your Galaxy Smartphone while it is charging
  • 1 amp charge output - charges all of Samsung's latest Smartphones including Galaxy S3, Galaxy Note and the Nexus Galaxy range
Samsung Travel Adapter - power adapter
Power adapter
Galaxy Nexus
Power adapter
Samsung Galaxy Nexus
Scroll to top
