BT.com
Wishlist
Samsung M3820ND Mono Laser Printer
£195.62
More than 50 in stock
£195.62
Add to wishlist
Delivery
Standard 1-3 working days
High productivity,cost-efficiency and versatility
Create professional documents more quickly
  • High speed printing of up to 38 ppm (pages per minute).
  • Higher-quality print output
  • ReCP (Rendering engine for Clean Page) technology for sharp text and clear images.
  • 1,200 x 1,200 effective dpi (dots per inch) resolution.
  • Additional printing choices for professional documents
  • A multipurpose tray that handles wide range of media, up to 220 gsm (grams per square meter), such as labels, cardstock and envelopes.
Reduce operating expenses with economical features and solutions
Professional eco solution
  • Easy Eco Driver enables users to set options to remove unnecessary text or images and also change the layout such as N-up printing without changing the original documents before printing.
  • One Touch Eco Button automatically activates 2-up (two pages on one side of the paper) and duplex printing, toner-save mode and the option to skip blank pages.
  • More toner options, more choices for cost reduction**
  • Diverse toner options from 3,000 to 10,000 page yields that meet every businesses' needs for reducing cost per page.
  • An integrated toner system contains the imaging unit and toner cartridge in one convenient package. This integrated toner system is the preferred choice for businesses with a heavier printing volume who require a lower CPP and easier maintenance.
Central print usage control to save more resources
  • Samsung SyncThruTM Admin solution enables management to assign users to specific devices, and assign predetermined quotas for the number of printed pages or copies by user.
Improve productivity with versatile features from duplex printing to security
  • Built-in duplex printing
  • Provides professional two-sided documents, brochures, and booklets with ease, which can also help save money and reduce paper use.
  • Mobile printing, easier than ever
  • Convenient mobile print, scan and fax with powerful compatibility, optimized for various business environments.
  • Enterprise-level document security offers greater control of user, document and network access.
Streamline printing with ease-of-use design
  • Easy Printer Manager for smooth print operation from toner and job ccounting to device settings.
  • Easy secure printing with built-in numeric key pad.
  • Easy connection through wireless printing without access point.
Samsung ProXpress M3820ND - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
10.18 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN
600 MHz
RAM Installed (Max)
128 MB (512 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, SPL (Samsung Printer Language), IBM ProPrinter, EPSON
Media Type
Envelopes, transparencies, labels, plain paper, cards, recycled paper, cotton paper, bar code labels, thick paper, thin paper
Total Media Capacity
300 sheets
Media Handling
250-sheet paper cassette, 50-sheet bypass tray
Monthly Duty Cycle (max)
80000 pages
UNIX, Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.8
36.6 cm x 36.56 cm x 26.25 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB 2.0, LAN
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
6.5 sec
Language Simulation
Media Handling
600 MHz
RAM
RAM Installed (Max)
128 MB / 512 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
820 sheets
Output Trays Capacity
150 sheets
Duty Cycle
80000 pages
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 3000 pages
Google Cloud Print
Power supply - internal
700 Watt
Power Consumption Stand by
10 Watt
Power Consumption Sleep
1.1 Watt
Sound Emission (Idle)
26 dBA
Sound Emission (Operating)
57 dBA
36.6 cm
36.56 cm
26.25 cm
10.18 kg
Scroll to top
