BT.com
Wishlist
Samsung M2875FD Mono Laser Multifunction Printer
Delivery
Standard Due date unavailable
Powerful, affordable, and simple to use
Reduce print costs but don't settle for less than the best. An efficient Samsung Xpress M2875FD Series gives you the speed you need to be more productive, but there's no compromise on quality. What's more, thanks to mobile printing and Easy Printer Manager software, these printers are also designed to be easy to use.
Print fast, don't wait
However demanding your professional printing needs, a Samsung Xpress M2875FD Series gives you great results - fast. Save time by printing even complex documents at speeds of up to 28 pages per minute (PPM) thanks to a powerful 600MHz processor and 128MB of memory. With the Cortex-A5 Core, it's up to 25.6% faster than earlier models, making it one of the fastest printers in its class. That means it helps you to work faster, be more flexible and more produc-tive.
Give a good impression with great print quality
Now impressive professional-quality prints are possible for everyone. Your Samsung Xpress M2875FD Series delivers sharp, clear prints that are sure to make a big impact. Thanks to its 4800 x 600 dpi effective resolution and Rendering Engine for Clean Page (ReCP) technology, you can enjoy higher perfor-mance and quality without the need for a bulky larger printer. What's more, quality-boosting features give you more detail, smoother images and clearer text.
High-resolution printing
Even complex images and small text are delivered in fine, detailed prints, thanks to high-resolution print quality up to 4800 x 600 dpi effective
Edge enhancement
Enjoy clearer text and more vivid images thanks to edge enhancement, which gives them a far more polished and well-defined edge.
Great copying and clear, colourful scanning
With your Samsung Xpress M2875FD Series, superior-quality copies and scans are now a reality. Great performance means fine text and images are sharper, delivering much more legible text and vibrant, smooth images.
Enhances thin lines and small text
Unlike some others, Samsung Xpress M2875FD Series ensure thin lines and small text are captured when scanning or copying. De-Integrated Cavity Effect (De-ICE) technology maximises the amount of text that is captured, delivering higher-quality prints and scans.
No more halftone patterns
With a Samsung Xpress M2875FD Series, you can remove halftone patterns on images and enjoy the clear and smooth images you need for truly pro-fessional print results.
Print with more paper types for all kinds of uses
Whatever you need to print, your Samsung Xpress M2875FD Series can handle it. The small but robust printer can use a range of media up to 220 grams per square meter (gsm), including paper, labels, cards, envelopes and overhead projector (OHP) transparencies. You can easily select the paper type you need from the multipurpose (MP) tray, so it's convenient as well as flexible.
Better for your budget and the planet
Cut your toner and paper costs with the One-Touch Eco Button. It's optimised, so just a click of the button allows you to easily use N-up and duplex printing, which lets you print multiple document pages on a single sheet and skip wasteful blank pages. With toner save mode, you can also reduce toner use and bring your printing costs down even more.
Cut energy and supply consumption
With Easy Eco Driver, you can make savings of up to 20% on toner and paper as well as reducing your energy usage. It helps you cut down on page elements that use high amounts of toner, such as images and bold type fonts, or lighten text so that less toner is required. You can preview and edit your documents before print-ing, to make sure that the output meets your needs in terms of efficiency and also quality. Eco Simulator also shows you the estimated reduction percentage of CO2, electricity, and paper, so you can see the difference for yourself.
Cut costs with Separated Toner System
With Samsung's Separated Toner System, the toner cartridge and imaging unit are supplied separately. This means you only need to buy the toner cartridge when it's empty, so the overall cost of running the printer - and the cost per page - is reduced. Installation is also easy, so you can spend less time maintaining your printer as well as less money. You can balance your budget as well as meet all your printing needs.
Monitor and manage your printer easily
Samsung's Easy Printer Manager lets you look after your printer's settings, device status, supply ordering and faxing - all in one place. You can conveniently see error reports and monitor the status of your printer and its supplies, as well as manage settings remotely. It's all provided in one single interface that brings together all your Samsung Printer's settings and applications.
Duplex printing
Duplex printing, or printing on both sides of paper, helps ensure that a minimal amount of paper and toner are wasted. Eco Mode lets you make sure all documents use duplex printing, so you can use supplies more efficiently and reduce your impact on the environment.
Network connectivity
Connect your printer across many different PCs and other devices that are connected to a single router. With this arrangement, it's possible for you to reduce the amount of money you spend on printing devices and energy consumption, yet be as productive as ever.
Mobile printing
Print what you need, wherever you are. You can now print a wide range of files on the go using a mobile device. Thanks to the included Google Cloud Print™, you're also able to print and share all your emails, photos, PDF documents, and SNS messages.
Fax
Thanks to built-in fax capabilities, you don't need a separate fax machine anymore. You can also transmit faxes remotely from your mobile devices, so you can send that important document wherever you are, without needing to return to your home or office.
Samsung Xpress M2875FD - multifunction printer (B/W)
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
12000 impressions
Max Copying Speed
Up to 28 ppm
Max Printing Speed
Up to 28 ppm
Max Printing Resolution
Up to 4800 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Original Size
142 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
120 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN
40.1 cm x 36.2 cm x 36.7 cm
11.3 kg
Environmental Standards
ENERGY STAR Qualified, EPEAT Bronze
Fax Type
Plain paper
Printing Technology
Laser - monochrome
12000 impressions
Display
2 lines
USB 2.0, LAN
Standard Memory
128 MB
Copying
Max Copying Speed
Up to 28 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2-up, 4-up, ID Card Copy, collation copy
Printing
Max Printing Speed
Up to 28 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, SPL
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 600 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Broadcast Transmission
209 stations
Fax forwarding, automatic redialing, last number redial, multi-send, delayed sending
Document & Media Handling
Min Original Size
142 x 148 mm
Max Original Size
Original Type
Sheets
40 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
120 sheets
ADF - 40 sheets size: 142 x 148 mm - Legal (216 x 356 mm) , Paper cassette - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 120 sheets
Speed Details
Printing: up to 28 ppm (A4) - B/W , Printing: up to 29 ppm (Letter A) - B/W , Copying: up to 28 ppm (A4) - B/W , Copying: up to 29 ppm (Letter A) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.5 - 10.8
Software Included
Drivers & Utilities
400 Watt
Power Consumption Standby
50 Watt
Power Consumption Sleep
1.1 Watt
First Copy Out Time B/W
15 sec
Consumables Included
1 x Cartridge (black) - up to 1200 pages
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
40.1 cm
36.2 cm
36.7 cm
11.3 kg
Sound Emission
26 dBA (idle) / 52 dBA (operating)
Resources
The following resources are available for the Samsung M2875FD Mono Laser Multifunction Printer
Scroll to top
