BT.com
Wishlist
Samsung LH40EDDPLGC 40" 1920x1080 DVI HDMI LED Large Format Display
Delivery
Standard Due date unavailable
Samsung ED series displays provide viewers with an exciting experience applicable to various scenarios such near-full scale fashion display or clear and legible large-conference display.
Samsung ED40D ED-D Series - 40" Class (40" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
40"
Diagonal Size
40 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote Control
Standard remote
Voltage
Energy Class
Class B
110 Watt
Power Consumption (On mode)
85 W
Energy Consumption per Year
124 kWh
92.54 cm x 9.36 cm x 54.1 cm
9.3 kg
Energy Class
Class B
110 Watt
85 W
124 kWh
Diagonal Class
40"
Diagonal Size
40 in
Commercial Use
Series
ED-D Series
TV Tuner
No tuner
Video Interface
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
92.54 cm
9.36 cm
54.1 cm
9.3 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Colour Depth
Up to 1.07 billion colours
Dynamic Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.15375 x 0.46125mm
Response Time
8 ms
Multiple Display Control (MDC), LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out
VGA cable
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Width (Shipping)
100.5 cm
Depth (Shipping)
15.1 cm
Height (Shipping)
61.5 cm
Weight (Shipping)
11.4 kg
Scroll to top
