BT.com
Wishlist
Samsung GALAXY Gear 360 Action Camera
Samsung GALAXY Gear 360 Action...
Free delivery
£229.00
Free delivery
More than 50 in stock
£229.00
Add to wishlist
Delivery
Standard 1-3 working days
4k 360 Video
The Gear 360 has evolved to let you record in 4K or broadcast live, and then make it your own with the Samsung Gear 360 app. And with the Gear 360's smaller size and redesigned, easy-to-grip body, memories aren't the only thing you'll want to hold onto.
Go live with Gear 360
Live broadcast moments you want to share with family and friends, whether it's a special event or just a look into your day-to-day activities. It's simple to set up: pair Gear 360 (2017) with your smartphone or PC, choose a platform to stream to, and provide a real-time peek into your life.
Easily shoot and share
Add a personal touch to your 360 content. The Samsung Gear 360 app allows you to switch up the view in a few taps, with multiple modes to choose from. Then, when you're ready to debut your new work, it's simple to convert 360 content into a standard video or photo format to upload wherever your audience is.
Go forth and record
The Gear 360 (2017) is made to catch the action all around you, and its sphere shape and dual cameras make that easy. So when you're in the middle of an adventure, it's a breeze to capture the moment in its entirety.
Handles well
When you're in the middle of recording, the last thing you want is a tired hand from holding the camera. The Gear 360 (2017) is smaller in size and a lighter weight—clocking in at just 130 g—so you don't have to worry. Just hold on tight and steady with the grip, which also serves as a stand, or easily attach it to a tripod or mount.
Record more, for longer
Catch every second with the long battery capacity of Gear 360 (2017), and have the space to record it all by inserting a micro SD card (up to 256GB). There's a lot of world to see, don't let anything get in the way of your exploring. (microSD card sold separately)
Samsung GALAXY Gear 360 (2017) - action camera
Action camera - 4K
Enclosure Colour
White
Camcorder Sensor Resolution
8.4 MP
Widescreen Video Capture
Optical Sensor Type
Dual CMOS
ISO (Max)
160
Sensors
Accelerometer, gyro sensor
Digital Video Format
H.265
Image Recording Format
JPEG
Max Video Resolution
4096 x 2048
USB 2.0, IEEE 802.11a/b/g/n/ac, Bluetooth 4.1
Connectivity Features
Wi-Fi Direct, remote control via mobile devices, remote live view, Wireless Image Transfer, Live streaming
Exposure & White Balance
Exposure Modes
Programme, automatic
White Balance
Automatic, presets
Lens System
2 x Lenses fisheye lens f/2.2 - fisheye
Focus Adjustment
Focus free
Additional Features
Low Lux / Night Mode
Additional Features
Time-Lapse recording, Loop recording, GPS via mobile
Action Camera Features
Camera Type
Mountable
Tripod Mount
Connection Point
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction
Connector Type
USB 2.0
Carrying strap, carrying pouch, USB cable
Protection
Splashproof, dust-resistant
Details
1 x 1160 mAh (included)
Battery Life Details
Video recording - 2.1 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Memory Card Max Supported Size
256 GB
Image Storage
JPEG 5472 x 2736 , JPEG 2304 x 1296
Video Capture
H.265 - 4096 x 2048 - 24 fps , H.265 - 2560 x 1280 - 30 fps , H.265 - 1920 x 1080 - 60 fps
4.63 cm
4.51 cm
10.06 cm
130 g
Scroll to top
