BT.com
Wishlist
Samsung Fast Charge Battery Pack (10 200mAh) Q/Charge 2.0 Black
Delivery
Standard Due date unavailable
Take high-speed charging technology on the go with the advanced 10200 mAh fast charge battery pack. This battery pack allows you to charge devices compatible with the main high-speed charging standards (Samsung Fast Charge and Qualcomm Quick Charge 2.0) at a much faster rate than traditional USB charging options. Now that support for QC2.0 charging technology has been added to Samsung's Fast Charge battery pack, this product will default to the superfast charging speed for your device. And with a universal USB port output, you can charge other smartphones, tablets or other electronics capable of charging via USB at standard charging rates. The battery pack's 10200 mAh capacity can be recharged over and over.
Samsung EB-PG935 - power bank
Power bank
7.71 cm x 2.3 cm x 10.42 cm
290 g
Output Connector Type
USB - on cable: Micro-USB
5 V
Voltage Provided
5 / 9 V
Fast Charge Technology
- 10200 mAh
Cables
Micro-USB cable - 20 cm
Galaxy S7, S7 edge
Power bank
7.71 cm
2.3 cm
10.42 cm
290 g
Enclosure Colour
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 / 9 V
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
2 A
LED indicator
10200 mAh
Samsung Galaxy S7, S7 edge
Scroll to top
