BT.com
Wishlist
Samsung ED75E 75" 1920 x 1080 VGA DVI HDMI LED Large Format Display
Samsung ED75E 75" 1920 x 1080 VGA...
£3,789.46
15 in stock
£3,789.46
Add to wishlist
Delivery
Standard 1-3 working days
Captivate your audience with stunning, full high-definition (FHD) images and crisp text on Samsung EDE Series displays. This affordable digital signage solution gives you the essential functionality you need to easily produce attention-grabbing messages. Their slim, lightweight design makes installation a snap compared with cumbersome conventional displays, saving you needless start-up expenses. The displays feature direct LED (d-LED) BLU technology for rich picture quality, low power consumption and reduced operating costs.
Samsung ED75E ED-E Series - 75" LED display
LED-backlit LCD flat panel display
Diagonal Class
75"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
275 Watt
Power Consumption (On mode)
215 W
Energy Consumption per Year
314 kWh
167.62 cm x 8.84 cm x 95.95 cm
34.1 kg
Energy Class
Class B
275 Watt
215 W
314 kWh
Diagonal Class
75"
Commercial Use
Series
ED-E Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Design
Narrow Bezel Design
167.62 cm
8.84 cm
95.95 cm
34.1 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Brightness
400 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.2865 x 0.8595mm
Response Time
4 ms
Mega Dynamic Contrast Ratio
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video input , Audio line-out , Serial
Batteries
VGA cable
CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, BSMI CNS 13438 Class A, NEMKO, NOM, SASO, CB, CCC, PSB, FCC, IRAM, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A, KC, GB 9254-2008, K60950-1, cUL No.60950-1, EAC, EN 55024-2:1998+A1:2001+A2:2003, GB4943.1-2011, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, EN55022:2006 + A1:2007, KN13, KN20, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
Power supply
Nominal Voltage
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
181 cm
Depth (Shipping)
25 cm
Height (Shipping)
108.5 cm
Weight (Shipping)
44.1 kg
10 - 80%
Scroll to top
