BT.com
Wishlist
Samsung ED65E 65" 1920x1080 VGA DVI HDMI LED Large Format Display
Samsung ED65E 65" 1920x1080 VGA DVI...
£2,511.61
£2,511.61
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
Samsung ED65E ED-E Series - 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
253 Watt
Power Consumption (On mode)
180 W
Energy Consumption per Year
263 kWh
146.74 cm x 5.62 cm x 84.8 cm
27.4 kg
Energy Class
Class B
253 Watt
180 W
263 kWh
Diagonal Class
65"
Commercial Use
Series
ED-E Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Design
Narrow Bezel Design
Dimensions
Without stand
146.74 cm
5.62 cm
84.8 cm
27.4 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Brightness
400 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.744 x 0.744mm
Response Time
6 ms
Mega Dynamic Contrast Ratio, Optional Touch Overlay
Stands & Mounts
Stand
Optional
Stand Design
Floor standing
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
VGA input , DVI-D input , Composite video input , Component video input , HDMI input , Audio line-in , Audio line-out , Serial input , Serial output
Batteries
VGA cable
CSA, UL, TUV, C-Tick, BSMI, GOST, NEMKO, SASO, CB, CCC, PSB, EK, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, K60950-1, cUL No.60950-1, EAC, GB4943.1-2011, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
Power supply
Nominal Voltage
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Width (Shipping)
160 cm
Depth (Shipping)
28.7 cm
Height (Shipping)
98 cm
Weight (Shipping)
35.4 kg
10 - 80%
Scroll to top
