BT.com
Wishlist
Samsung ED65D 65" 1920x1080 VGA DVI HDMI LED Large Format Display
Delivery
Standard Due date unavailable
Samsung ED series displays provide viewers with an exciting experience applicable to various scenarios such near-full scale fashion display or clear and legible large-conference display.
Samsung ED65D ED-D Series - 65" Class (65" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Diagonal Size
65 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Remote Control
Standard remote
Voltage
Energy Class
Class B
290 Watt
Power Consumption (On mode)
185 W
Energy Consumption per Year
270 kWh
146.75 cm x 6.5 cm x 84.8 cm
26.8 kg
Energy Class
Class B
290 Watt
185 W
270 kWh
Diagonal Class
65"
Diagonal Size
65 in
Commercial Use
Series
ED-D Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
146.75 cm
6.5 cm
84.8 cm
26.8 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Multiple Display Control (MDC), LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out , Serial input , Serial output
VGA cable
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
10 - 80% (non-condensing)
Scroll to top
