BT.com
Wishlist
Samsung ED55D 55" 1920x1080 DVI HDMI LED Large Format Display
Delivery
Standard Due date unavailable
Samsung ED series displays provide viewers with an exciting experience applicable to various scenarios such near-full scale fashion display or clear and legible large-conference display.
Samsung ED55D ED-D Series - 55" Class (55" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
55 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote Control
Standard remote
Voltage
Energy Class
Class B
165 Watt
Power Consumption (On mode)
140 W
Energy Consumption per Year
204 kWh
124.77 cm x 9.48 cm x 72.29 cm
18.3 kg
Energy Class
Class B
165 Watt
140 W
204 kWh
Diagonal Class
55"
Diagonal Size
55 in
Commercial Use
Series
ED-D Series
TV Tuner
No tuner
Video Interface
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
124.77 cm
9.48 cm
72.29 cm
18.3 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Dynamic Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.21 x 0.63mm
Response Time
8 ms
Multiple Display Control (MDC), LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out
VGA cable
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Width (Shipping)
138.1 cm
Depth (Shipping)
17 cm
Height (Shipping)
83.8 cm
Weight (Shipping)
23.4 kg
Accessories
£49.51
Scroll to top
