BT.com
Wishlist
Samsung ED46C 46" 1920x1080 8ms VGA (HD-15) LED Large Format Display
Samsung ED46C 46" 1920x1080 8ms VGA...
£577.41
£577.41
Add to wishlist
Delivery
Standard Due date unavailable
Samsung ED series displays provide viewers with an exciting experience applicable to various scenarios such near-full scale fashion display or clear and legible large-conference display.
Samsung ED46D ED-D Series - 46" Class (46" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Diagonal Size
46 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote Control
Standard remote
Voltage
Energy Class
Class B
121 Watt
Power Consumption (On mode)
98 W
Energy Consumption per Year
143 kWh
105.77 cm x 9.48 cm x 61.58 cm
11.9 kg
Energy Class
Class B
121 Watt
98 W
143 kWh
Diagonal Class
46"
Diagonal Size
46 in
Commercial Use
Series
ED-D Series
TV Tuner
No tuner
Video Interface
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
105.77 cm
9.48 cm
61.58 cm
11.9 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
Up to 1.07 billion colours
Dynamic Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.17675 x 0.53025mm
Response Time
8 ms
Multiple Display Control (MDC), LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out
VGA cable
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Width (Shipping)
115.4 cm
Depth (Shipping)
16.5 cm
Height (Shipping)
72.3 cm
Weight (Shipping)
14.6 kg
Scroll to top
