BT.com
Wishlist
Samsung ED32D 32" 1366x768 8ms VGA DVI-D HDMI LED Large Format Display
Delivery
Standard Due date unavailable
Captivate your audience with stunning, high-definition (HD) images and crisp text on Samsung EDD large format display (LFD) Series. This digital signage solution gives you the essentials you need to easily produce attention-getting messages in one affordable display. Their slim, lightweight design makes installation a snap compared with cumbersome conventional displays, saving you needless start-up expenses. The displays feature direct LED (d-LED) BLU technology for rich picture quality, low power consumption and reduced operating costs.
Captivate your audience with an immersive viewing experience. Entice your audience with crisp, clear HD images and realistic color on a sleek display with Samsung d-LED technology. A sleek, lightweight design and slim bezels keep your audience focus on your message, helping you capture more business opportunities. The accompanied pivot function gives you the flexibility to display your message vertically or horizontally for the optimal view.
Samsung ED32D ED-D Series - 32" Class (32" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Diagonal Size
32 in
Commercial Use
Yes - digital signage
Resolution
1366 x 768
Display Format
720p
Video Interface
Component, composite, HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote Control
Standard remote
Voltage
Energy Class
Class B
77 Watt
Power Consumption (On mode)
48 W
Energy Consumption per Year
70 kWh
73.6 cm x 9.37 cm x 43.45 cm
6 kg
Energy Class
Class B
77 Watt
48 W
70 kWh
Diagonal Class
32"
Diagonal Size
32 in
Commercial Use
Series
ED-D Series
TV Tuner
No tuner
Video Interface
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
73.6 cm
9.37 cm
43.45 cm
6 kg
Enclosure Colour
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Dynamic Contrast Ratio
4000:1
Brightness
330 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.17025 x 0.51075mm
Response Time
8 ms
Multiple Display Control (MDC), LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out
VGA cable
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Width (Shipping)
82.6 cm
Depth (Shipping)
16.2 cm
Height (Shipping)
53 cm
Weight (Shipping)
7.6 kg
Scroll to top
