BT.com
Wishlist
Samsung EB-B600BEB - Cellular Phone Battery - Li-Ion
Delivery
Standard Due date unavailable
The Galaxy S4 standard battery is a high-quality battery that has been designed specifically to deliver the most reliable and long-lasting power for your Samsung Galaxy S4. This battery is equipped with an NFC antenna, allowing your handset to communicate with other devices and accessories that are equipped with NFC technology.
This battery, exclusively for Samsung Smartphones, offers longer battery life, is reliable and safe, having gone through an exhausting testing and certification process. For long travels or extended use, have the peace of mind of an extra Samsung battery on hand when you need it.
Samsung EB-B600BEB - battery Li-Ion
5.7 cm x 5.3 cm x 6.3 cm
43.9 g
Lithium Ion 2600 mAh standard
Galaxy S4
5.7 cm
5.3 cm
6.3 cm
43.9 g
Standard
Lithium Ion
Voltage Provided
3.8 V
2600 mAh
NFC aerial
Samsung Galaxy S4
Scroll to top
