BT.com
Wishlist
Samsung DM82D 82" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Samsung DM82D 82" 1920x1080 VGA DVI...
£7,414.58
More than 50 in stock
£7,414.58
Add to wishlist
Delivery
Standard 1-3 working days
Samsung's DM82D delivers 24/7 reliability on a large 82" screen for continuous operation. Display content without an external PC thanks to an upgraded Samsung SMART Signage Platform (SSP) and full range of connectivity options. All combined with a sleek industrial design and slim 1.9" chassis depth.
Samsung DM82D DM-D Series - 82" Class (81.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
82"
Diagonal Size
81.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
120Hz Refresh Rate
Video Wall Components Qty
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery, SMART Signage Platform 2nd Generation
Speaker System
2 speakers
Storage Drive Capacity
4 GB
Supported Memory Cards
SD Memory Card
USB
2 ports
Remote Control
Standard remote
Voltage
363 Watt
185.42 cm x 4.85 cm x 106.42 cm
50 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
363 Watt
Diagonal Class
82"
Diagonal Size
81.5 in
Commercial Use
Series
DM-D Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
225
Dimensions
Without stand
185.42 cm
4.85 cm
106.42 cm
50 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
120Hz Refresh Rate
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
50000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.3135 x 0.9405 mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, digital daisy chain, Smart Scheduling, Quad-Core processor, e-LED BLU, MagicInfo Player-S2
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
Supported Video Formats
MPEG-1, MPEG-2, AVC, H.264, VC-1
Supported Audio Formats
AC3, DTS
Supported Pictures Formats
JPG, PNG
SD Memory Card
USB Port
USB Ports Qty
2
PC Configuration
ARM Cortex-A9 / 1 GHz / 1.5 GB DDR3
4 GB
Operating System
Linux
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi, LAN
Connector Type
Serial input , Serial output , Remote control/ambient sensor input , Audio line-out , Audio line-in , 2 x USB , DVI-D input , DisplayPort input , 3 x HDMI input , VGA input , DisplayPort output , Composite video / component video / audio input , Remote control output , Multiple Display Control
Batteries
VGA cable
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, EK, IRAM, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, GB4943.1-2011, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST 22505-97, EN55022:2006 + A1:2007, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, GOST-R 51317, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
3 years warranty
Limited warranty - 3 years
Width (Shipping)
200.2 cm
Depth (Shipping)
46.2 cm
Height (Shipping)
123.8 cm
Weight (Shipping)
65 kg
10 - 80% (non-condensing)
Scroll to top
