BT.com
Wishlist
Samsung DM55E 55" 1920x1080 VGA DVI HDMI DisplayPort WiFi LED Large Format Display
Samsung DM55E 55" 1920x1080 VGA DVI...
£1,410.34
More than 50 in stock
£1,410.34
Add to wishlist
Delivery
Standard 1-3 working days
Enhance your brand image and messaging with Samsung DME Series SMART Signage professional-grade displays. With vivid picture quality, high-brightness screens (450 nit) and exceptional 24/7 durability, DME displays offer the functionality you need to promote your business.
Powered by the enhanced 3rd Generation Samsung SMART Signage Platform (SSSP), DME Series displays deliver rich content without an additional PC or media player. Samsung's MagicInfo Player S3 is also equipped with a range of intuitive features, such as decorative icons, drag and drop functionality and various fonts, and with Samsung's convenient mobile app, you can manage your digital signage from virtually anywhere through a smart phone or tablet.
Samsung DM55E DME Series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
Remote Control
Standard remote
Voltage
Energy Class
Class B
176 Watt
Power Consumption (On mode)
130 W
Energy Consumption per Year
190 kWh
123.06 cm x 4.99 cm x 70.69 cm
15.4 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
176 Watt
130 W
190 kWh
Diagonal Class
55"
Commercial Use
Series
DME Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
225
Dimensions
Without stand
123.06 cm
4.99 cm
70.69 cm
15.4 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
50000:1
Brightness
450 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.21 x 0.63mm
Response Time
6 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, MagicInfo, LED BLU, MagicInfo Player-S3
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
SD Memory Card
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in speaker
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , 2 x HDMI input , Audio line-in , Component video input , Audio line-out , DisplayPort input , Serial , DisplayPort output
VGA cable , Serial adapter
Plug and Play, CSA, UL, C-Tick, BSMI, BSMI CNS 13438 Class A, cUL, NEMKO, SASO, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, EN55024:1998 + A1:2001 + A2:2003, GB 4943-2011, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
134.8 cm
Depth (Shipping)
14.8 cm
Height (Shipping)
81 cm
Weight (Shipping)
19.5 kg
10 - 80%
Scroll to top
