BT.com
Wishlist
Samsung DM55D 55" 1920x1080 VGA DVI LED Large Format Display
Samsung DM55D 55" 1920x1080 VGA DVI...
£1,785.88
£1,785.88
Add to wishlist
Delivery
Standard Due date unavailable
Because of its outstanding durability and performance, DMD series digital signage is the ideal solution for any business or organization whose revenue is dependent on non-stop operation. By leveraging Samsung's proven technology, you can increase sales by continually drawing and informing audiences with rich content delivered on superb-quality digital signage. With highly visible and superior 450-nit brightness, DMD series digital signage keeps viewers engaged in any indoor business environment.
DMD series digital signage is powered by a significantly upgraded embedded SSSP. The industry-leading quad-core SoC processor substantially improves the performance with a remarkably faster processing speed for rich, seamless messaging. The increased power supports interactive digital signage capability. This world's first feature amplifies your messaging with engaging interactivity, without the need for an additional PC. Now, schools, corporations and other businesses can offer interactive signage with less expense and difficulty. In addition, the SSSP supports a picture-in-picture (PIP) size over 50 percent of the digital signage area for operational excellence, compared to less than 50 percent in dual-core digital signage.
Samsung DM55D DM-D Series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Magic Clone, Auto Source Switching & Recovery
Supported Memory Cards
SD Memory Card
USB
Remote Control
Standard remote
Voltage
Energy Class
Class B
176 Watt
Power Consumption (On mode)
135 W
Energy Consumption per Year
197 kWh
123.06 cm x 4.99 cm x 70.69 cm
15.4 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
176 Watt
135 W
197 kWh
Diagonal Class
55"
Commercial Use
Series
DM-D Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
123.06 cm
4.99 cm
70.69 cm
15.4 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Dynamic Contrast Ratio
5000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.21 x 0.63mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, MagicInfo, LED BLU, Smart Scheduling
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
SD Memory Card
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Built-in speaker
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out , DisplayPort input , DisplayPort output , USB 2.0
VGA cable
TUV, GOST, cUL, EN 60950, EN55022, NOM, PCBC, SASO, SIQ, IEC 60950, UL 60950, CB, CCC, EMC, PSB, EK, IRAM, K60950, NOM-001-SCFI-1993 IRAM, GB 4943.1, IS13252
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
134.8 cm
Depth (Shipping)
14.8 cm
Height (Shipping)
81 cm
Weight (Shipping)
19.5 kg
10 - 80%
Scroll to top
