BT.com
Wishlist
Samsung DM48E 48" 1920x1080 VGA DVI HDMI DisplayPort WiFi LED Large Format Display
Samsung DM48E 48" 1920x1080 VGA DVI...
£1,735.98
£1,735.98
Add to wishlist
Delivery
Standard Due date unavailable
Enhance your brand image and messaging with Samsung DME Series SMART Signage professional-grade displays. With vivid picture quality, high-brightness screens (450 nit) and exceptional 24/7 durability, DME displays offer the functionality you need to promote your business.
Powered by the enhanced 3rd Generation Samsung SMART Signage Platform (SSSP), DME Series displays deliver rich content without an additional PC or media player. Samsung's MagicInfo Player S3 is also equipped with a range of intuitive features, such as decorative icons, drag and drop functionality and various fonts, and with Samsung's convenient mobile app, you can manage your digital signage from virtually anywhere through a smart phone or tablet.
Samsung DM48E DME Series - 48" Class (47.6" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
48"
Diagonal Size
47.6 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Wall Components Qty
225
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
DVR
Flash - 8 GB
Storage Drive Capacity
8 GB
Supported Memory Cards
SD Memory Card
USB
Remote Control
Standard remote
Voltage
Energy Class
Class B
132 Watt
Power Consumption (On mode)
94 W
Energy Consumption per Year
137 kWh
107.51 cm x 4.99 cm x 61.94 cm
11.1 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
132 Watt
94 W
137 kWh
Diagonal Class
48"
Diagonal Size
47.6 in
Commercial Use
Series
DME Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
225
Dimensions
Without stand
107.51 cm
4.99 cm
61.94 cm
11.1 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
50000:1
Brightness
450 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.183 x 0.549mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, digital daisy chain, MagicInfo, Quad-Core processor, d-LED BLU, MagicInfo Player-S3
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
DVR
DVR
Flash - 8 GB
Media Player
Supported Video Formats
MPEG-1, MPEG-2, AVC, H.264, VC-1
Supported Audio Formats
AC3, DTS
Supported Pictures Formats
PNG, JPEG
SD Memory Card
USB Port
USB Ports Qty
1
PC Configuration
ARM Cortex-A9 / 1 GHz / 1.5 GB DDR3
8 GB
Operating System
Linux
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
Serial input , Serial output , Remote control/ambient sensor input - rear , Audio line-out - rear , Audio line-in - rear , USB 2.0 - rear , DVI-D input - rear , DisplayPort input - rear , 2 x HDMI input - rear , VGA input - rear , DisplayPort output - rear , Component video input - rear , Remote control output - rear , Multiple Display Control - rear
Batteries
VGA cable , Serial adapter
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, EK, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, EAC, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, GB 4943-2011, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, BIS, INMETRO
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Width (Shipping)
118.5 cm
Depth (Shipping)
14.8 cm
Height (Shipping)
71.5 cm
Weight (Shipping)
14 kg
10 - 80%
Scroll to top
