BT.com
Wishlist
Samsung DH55D 55" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Free delivery
Delivery
Standard Due date unavailable
Convey your business messaging with style through Samsung's impeccable, highly reliable DHD Series SMART signage. This innovative signage solution provides an immersive viewing experience by delivering crystal-clear images while operating 24/7 Powered by the newest version of the embedded content management solution, the 2nd Generation SSSP (Samsung Smart Signage Platform), Samsung DHD Series does not require an additional PC or media player, even for touch interactivity, allowing you to promote your business, attract viewers and increase revenues all while enjoying reduced overhead and a lowered initial investment. Additionally, this robust all-in-one software solution enables you to manage your digital signage remotely from virtually anywhere using a Wi-Fi-enabled mobile device.
Samsung DH55D DHD series - 55" Class (55" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
55 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
Component, composite, HDMI
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
USB
Remote Control
Standard remote
Voltage
Energy Class
Class B
175 Watt
Power Consumption (On mode)
127 W
Energy Consumption per Year
185 kWh
123.72 cm x 5.24 cm x 71.35 cm
17.1 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
175 Watt
127 W
185 kWh
Diagonal Class
55"
Diagonal Size
55 in
Commercial Use
Series
DHD series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
PC Interface
HDCP Compatible
225
Dimensions
Without stand
123.72 cm
5.24 cm
71.35 cm
17.1 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.21 x 0.63mm
Response Time
6 ms
Commercial Features
Pivot, digital daisy chain, d-LED BLU, key lock, MagicInfo Player-S2
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
SD Memory Card
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , DisplayPort , HDMI , Composite video / component video input , Audio line-in , DisplayPort output , Audio line-out , USB 2.0
VGA cable , Serial adapter
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, EK, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, GB4943.1-2011, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST 22505-97, EN55022:2006 + A1:2007, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, GOST-R 51317, NOM-001-SCFI-1993, BIS, INMETRO
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Weight (Shipping)
21.5 kg
10 - 80%
Scroll to top
