BT.com
Wishlist
Samsung DH40E 40" 1920x1080 VGA DVI HDMI DisplayPort WiFi LED Large Format Display
Samsung DH40E 40" 1920x1080 VGA DVI...
£1,703.70
£1,703.70
Add to wishlist
Delivery
Standard Due date unavailable
These innovative and stylish DHE Series SMART Signage displays feature superb ultra-bright luminosity, consistent durability and performance, and a range of picture quality settings that can be optimized to suit virtually any environment. Powered by the enhanced 3rd Generation Samsung SMART Signage Platform (SSSP), DHE Series displays deliver rich content without an additional PC or media player. Samsung's MagicInfo Player S3 is also equipped with a range of intuitive features, such as decorative icons, drag and drop functionality and various fonts, and with Samsung's convenient mobile app, you can manage your digital signage from virtually anywhere through a smart phone or tablet.
Samsung DH40E DHE Series - 40" LED display
LED-backlit LCD flat panel display
Diagonal Class
40"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
Remote Control
Standard remote
Voltage
Energy Class
Class B
135 Watt
Power Consumption (On mode)
85 W
Energy Consumption per Year
124 kWh
91.32 cm x 5.24 cm x 53.13 cm
8.6 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
135 Watt
85 W
124 kWh
Diagonal Class
40"
Commercial Use
Series
DHE Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
225
Dimensions
Without stand
91.32 cm
5.24 cm
53.13 cm
8.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
50000:1
Brightness
700 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.15375 x 0.46125mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, digital daisy chain, MagicInfo, LED BLU, MagicInfo Player-S3
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
SD Memory Card
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in speaker
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Audio line-out , DisplayPort input , DisplayPort output
Batteries
VGA cable , Serial adapter
Plug and Play, CSA, UL, C-Tick, BSMI, BSMI CNS 13438 Class A, cUL, NEMKO, SASO, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, GB 4943-2011, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
106.2 cm
Depth (Shipping)
11.5 cm
Height (Shipping)
60 cm
Weight (Shipping)
10.4 kg
10 - 80%
Scroll to top
