BT.com
Wishlist
Samsung DH40D 40" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Samsung DH40D 40" 1920x1080 VGA DVI...
£656.47
£656.47
Add to wishlist
Delivery
Standard Due date unavailable
Convey your business messaging with style and power through impeccable, highly reliable Samsung DHD Series digital signage. This innovative digital signage solution provides an immersive viewing experience by delivering crystal-clear images, while operating flawlessly 24/7 to promote your business, attract viewers and increase revenues. Powered by an upgraded 2nd generation Samsung smart signage platform (SSSP) all-in-one embedded content management solution, Samsung DHD Series digital signage doesn't require an additional PC or media player, even for touch interactivity. Plus, you can easily manage the digital signage remotely from virtually anywhere using a Wi-Fi-enabled mobile device. And, with proven technology from an industry leader, DHD Series digital signage is a premium signage lineup for those who consider high durability and exceptional performance as essential.
Samsung DH40D DHD series - 40" Class (40" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
40"
Diagonal Size
40 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
Component, composite, HDMI
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
Remote Control
Standard remote
Voltage
Energy Class
Class C
135 Watt
Power Consumption (On mode)
90 W
Energy Consumption per Year
131 kWh
91.32 cm x 5.24 cm x 53.13 cm
8.6 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class C
135 Watt
90 W
131 kWh
Diagonal Class
40"
Diagonal Size
40 in
Commercial Use
Series
DHD series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
PC Interface
HDCP Compatible
225
Dimensions
Without stand
91.32 cm
5.24 cm
53.13 cm
8.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-reflection
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Brightness
700 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.15375 x 0.46125mm
Response Time
8 ms
Commercial Features
Pivot, MagicInfo, Quad-Core processor, d-LED BLU, MagicInfo Player-S2
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
SD Memory Card
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , DisplayPort , HDMI , Composite video / component video input , Audio line-in , DisplayPort output , Audio line-out
VGA cable , Serial adapter
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, EN55022, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, EK, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, GB4943.1-2011, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST 22505-97, EN55022:2006 + A1:2007, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, GOST-R 51317, NOM-001-SCFI-1993, BIS, INMETRO
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Weight (Shipping)
10.5 kg
10 - 80%
Scroll to top
