BT.com
Wishlist
Samsung DC32E 32" 1920x1080 VGA DVI HDMI LED Large Format Display
Samsung DC32E 32" 1920x1080 VGA DVI...
£365.80
More than 50 in stock
£365.80
Add to wishlist
Delivery
Standard 1-3 working days
Captivate your audience with stunning, Full HD images and crisp text on Samsung DCE series displays. This digital signage solution gives you the essential functionality you need to easily produce attention-grabbing messages. Its slim, lightweight design makes installation a snap compared with cumbersome conventional displays, saving you needless start-up expenses. The displays feature direct LED BLU technology for rich picture quality, low power consumption and reduced operating costs.
Samsung DC32E DCE Series - 32" LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform
Speaker System
1 speaker
USB
Remote Control
Standard remote
Energy Class
Class B
Power Consumption (On mode)
50 W
Energy Consumption per Year
73 kWh
72.14 cm x 4.99 cm x 42.03 cm
4.8 kg
Energy Class
Class B
50 W
73 kWh
Diagonal Class
32"
Commercial Use
Series
DCE Series
TV Tuner
No tuner
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
72.14 cm
4.99 cm
42.03 cm
4.8 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Image Contrast Ratio
5000:1
Brightness
330 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
MagicInfo Lite, d-LED BLU, Mega Dynamic Contrast Ratio, Certified for 16/7 Continuous Operation
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
1 speaker
Output Power / Total
10 Watt
Speakers
1 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , Network , Audio line-in , Audio line-out , 2 x HDMI input , DVI-D input , Composite video input , Remote control , Serial , USB
Batteries
Serial adapter
Width (Shipping)
81.5 cm
Depth (Shipping)
13.2 cm
Height (Shipping)
49.1 cm
Weight (Shipping)
5.9 kg
10 - 80%
Scroll to top
