BT.com
Wishlist
Samsung DB22D-P 21.5" 1920x1080 VGA HDMI WiFi LED Large Format Display
Samsung DB22D-P 21.5" 1920x1080 VGA...
£333.70
36 in stock
£333.70
Add to wishlist
Delivery
Standard 1-3 working days
Samsung's DB22D-P provides a fully embedded solution to manage digital signage content without connecting external devices. An enhanced Samsung SMART Signage Platform (SSP) features a quad core processor, combined with media player functionality via System-on-Chip (SoC), and MagicInfo software. The 22" form factor fits small placements, while full HD resolution delivers sharp, stunning images.
Samsung DB22D-P 22" Class (21.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
22"
Diagonal Size
21.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
44 Watt
50.75 cm x 5.78 cm x 31.12 cm
3.6 kg
44 Watt
Diagonal Class
22"
Diagonal Size
21.5 in
Commercial Use
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode
Dimensions
Without stand
50.75 cm
5.78 cm
31.12 cm
3.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
60 Hz Refresh Rate
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Dynamic Contrast Ratio
50000:1
Brightness
250 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.2482 x 0.2482mm
Response Time
14 ms
Commercial Features
Multiple Display Control (MDC), Smart Scheduling, e-LED BLU, MagicInfo Player-S2
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm
Media Player
USB Port
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
2 Watt
Built-in speaker
Speakers
2 x main channel speaker - built-in - 1 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
HDMI input , VGA input , Audio line-in , Multiple Display Control , USB
Batteries
VGA cable
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, DDC-2B, NEMKO, SASO, AS/NZS 60950-1, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, K60950-1, KCC KN22, KCC KN24, cUL No.60950-1, EAC, GB4943.1-2011, EN55024:1998 + A1:2001 + A2:2003, IS13252, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
57 cm
Depth (Shipping)
12.8 cm
Height (Shipping)
37.6 cm
Weight (Shipping)
4.9 kg
10 - 80%
Scroll to top
