BT.com
Wishlist
Samsung DB22D 21.5" 1920x1080 VGA HDMI SOC LED Large Format Display
Samsung DB22D 21.5" 1920x1080 VGA...
£368.29
£368.29
Add to wishlist
Delivery
Standard Due date unavailable
Present your business messages in the ideal way with affordable Samsung DB22D series digital signage that delivers flexible connectivity and high indoor performance. The affordable, embedded, all-in-one media solution with improved performance makes it easy to manage content while maintaining low total cost of ownership (TCO). Economical 21.5 inches Samsung DBD series digital signage features a distinctive, sleek design. Turn your small space into creative advertising and effective information sharing with Samsung's small-sized signage solution.
Samsung DB22D DB-D Series - 22" Class (21.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
22"
Diagonal Size
21.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
SMART Signage Platform, Image Rotation, Magic Clone
Speaker System
1 speaker
USB
2 ports
Remote Control
Standard remote
Voltage
Energy Class
Class B
40 Watt
Power Consumption (On mode)
31 W
Energy Consumption per Year
43 kWh
50.75 cm x 5.78 cm x 31.12 cm
3.3 kg
Energy Class
Class B
40 Watt
31 W
43 kWh
Diagonal Class
22"
Diagonal Size
21.5 in
Commercial Use
Series
DB-D Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
225
Dimensions
Without stand
50.75 cm
5.78 cm
31.12 cm
3.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Dynamic Contrast Ratio
50000:1
Brightness
250 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
170 degrees
Pixel Pitch
0.2482 x 0.2482mm
Response Time
5 ms
Commercial Features
Pivot, Multiple Display Control (MDC), MagicInfo, security lock slot (cable lock sold separately), e-LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
100 x 100 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Speaker System
1 speaker
Output Power / Total
10 Watt
Speakers
1 x main channel speaker - built-in - 10 Watt
Connector Type
HDMI input , VGA input , Serial input , Audio line-in , Multiple Display Control , 2 x USB 2.0
VGA cable ¦ Serial cable
Power supply
Nominal Voltage
Power Consumption Stand by
0.3 Watt
Width (Shipping)
57 cm
Depth (Shipping)
12.8 cm
Height (Shipping)
37.6 cm
Weight (Shipping)
4.5 kg
10 - 80%
Scroll to top
