BT.com
Wishlist
Samsung DB10E-PoE 10.1" 1280x800 HDMI LED Large Format Display
Samsung DB10E-PoE 10.1" 1280x800...
£356.47
41 in stock
£356.47
Add to wishlist
Delivery
Standard 1-3 working days
Equipped with a variety of integrated technologies, Samsung Small Signage enables you to deliver interactive and informative content with fewer external resources required. For space-conscious businesses, the DBE-PoE display offers a minimalistic connection format conducive to multiple device usage. Instead of requiring two separate cables for power and network connectivity, the PoE-enabled display just needs one cable to deliver a high-speed network connection while supplying 30 W of power at the same time. The elimination of cables and adapters ensures tidy installation, especially when multiple displays are installed in one location. In this way, the DBE-PoE minimizes visual distraction and enhances the visual appeal of your business environment and digital signage for customers.
Deliver myriad rich content with DBE Series built-in media player and simplified management through 3rd Generation Samsung SMART Signage Platform (SSSP). The embedded, all-in-one 3rd generation SSSP eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership (TCO).
Samsung DB10E-POE DBE Series - 10" Class (10.1" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
10"
Diagonal Size
10.1 in
Commercial Use
Yes - digital signage
Resolution
1280 x 800
Display Format
720p
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery, SMART Signage Platform 3nd Generation
DVR
Flash - 8 GB
Storage Drive Capacity
8 GB
Supported Memory Cards
SD Memory Card
USB
Remote Control
Standard remote
Voltage
Energy Class
Class D
20.9 Watt
Power Consumption (On mode)
18 W
Energy Consumption per Year
26 kWh
24.68 cm x 2.7 cm x 16.52 cm
700 g
Energy Class
Class D
20.9 Watt
18 W
26 kWh
Diagonal Class
10"
Diagonal Size
10.1 in
Commercial Use
Series
DBE Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
Modes
Portrait mode
Dimensions
Without stand
24.68 cm
2.7 cm
16.52 cm
700 g
Display
Resolution
1280 x 800
Display Format
720p
60 Hz Refresh Rate
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
900:1
Dynamic Contrast Ratio
50000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.1695 x 0.1695mm
Response Time
30 ms
Commercial Features
Multiple Display Control (MDC), Quad-Core processor, e-LED BLU, Certified for 16/7 Continuous Operation, MagicInfo Player-S3
Stands & Mounts
Flat Panel Mount Interface
75 x 75 mm
DVR
DVR
Flash - 8 GB
Media Player
SD Memory Card
USB Port
PC Configuration
ARM Cortex-A9 / 1 GHz / 1.5 GB DDR3
8 GB
Operating System
Linux
Remote Control
Standard remote
Connector Type
HDMI input , Serial input , Network , USB 2.0 , Audio line-out , USB 2.0 upstream
Batteries
Serial cable
Plug and Play, UL, C-Tick, BSMI, DDC-2B, EN55022, NOM, SASO, IEC 60950, EN55024, CB, CCC, PSB, UL 60950-1, EN 60950-1, FCC CFR47 Part 15 B, S Mark, CAN/CSA C22.2 No. 60950-1, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, EAC, CNS 13438, GB 17625.1-2012, IEC60950-1, VCCI - V-3/2014.04, AS/NZS CISPR22:2009+A1:2010
Power supply
Nominal Voltage
Power Consumption Stand by
0.4 Watt
Width (Shipping)
30 cm
Depth (Shipping)
7.9 cm
Height (Shipping)
20.5 cm
Weight (Shipping)
1.5 kg
10 - 80% (non-condensing)
Scroll to top
