BT.com
Wishlist
Samsung DB10D 10.1" 1280x800 HDMI SOC LED Large Format Display
Samsung DB10D 10.1" 1280x800 HDMI...
£237.03
£237.03
Add to wishlist
Delivery
Standard Due date unavailable
Samsung's compact DB10D series displays provide an engaging, personalized customer experience through effective, targeted communication. Exceptionally durable and longlasting, these displays support multiple connectivity and easy content management with Samsung's embedded, all-in-one software solution and built-in media player. The Wide Viewing Angle panel ensures content is visible from the entire room. This allows you to make the most of your limited space in a more creative and impactful way.
Samsung DB10D DB-D Series - 10" Class (10.1" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
10"
Diagonal Size
10.1 in
Commercial Use
Yes - digital signage
Resolution
1280 x 800
Display Format
720p
Motion Enhancement Technology
60 Hz Refresh Rate
Video Wall Components Qty
225
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Commercial Features
Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery, SMART Signage Platform 2nd Generation
Speaker System
1 speaker
DVR
Flash - 4 GB
Storage Drive Capacity
4 GB
Supported Memory Cards
SD Memory Card
USB
Remote Control
Standard remote
Voltage
Energy Class
Class C
18.7 Watt
Power Consumption (On mode)
18 W
Energy Consumption per Year
26 kWh
24.68 cm x 2.49 cm x 16.52 cm
600 g
Energy Class
Class C
18.7 Watt
18 W
26 kWh
Diagonal Class
10"
Diagonal Size
10.1 in
Commercial Use
Series
DB-D Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
Modes
Portrait mode
225
Dimensions
Without stand
24.68 cm
2.49 cm
16.52 cm
600 g
Display
Resolution
1280 x 800
Display Format
720p
60 Hz Refresh Rate
Colour Depth
16.7 million colours
Image Contrast Ratio
900:1
Dynamic Contrast Ratio
50000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.1695 x 0.1695mm
Response Time
30 ms
Commercial Features
Multiple Display Control (MDC), Smart Scheduling, Quad-Core processor, e-LED BLU, MagicInfo Player-S2, Certified for 16/7 Continuous Operation
Stands & Mounts
Flat Panel Mount Interface
50 x 50 mm
DVR
DVR
Flash - 4 GB
Media Player
Supported Video Formats
MPEG-1, MPEG-2, AVC, H.264, VC-1
Supported Audio Formats
AC3, DTS
Supported Pictures Formats
JPG, PNG
SD Memory Card
USB Port
USB Ports Qty
1
PC Configuration
ARM Cortex-A9 / 1 GHz / 1 GB DDR3
4 GB
Operating System
Linux
Remote Control
Standard remote
Audio System
Speaker System
1 speaker
Output Power / Total
1 Watt
Speakers
1 x main channel speaker - built-in - 1 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
HDMI input , Serial input , Multiple Display Control , USB 2.0
Batteries
Serial cable
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, GOST, cUL, DDC-2B, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, EMC, PSB, EK, IRAM, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, GB4943.1-2011, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, EN55022:2006 + A1:2007, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
30 cm
Depth (Shipping)
7.9 cm
Height (Shipping)
20.5 cm
Weight (Shipping)
1.2 kg
10 - 80% (non-condensing)
Scroll to top
