BT.com
Wishlist
Samsung CLP-415NW - Printer - colour - laser - 18 ppm - Wireless
Samsung CLP-415NW - Printer -...
£206.84
£206.84
Add to wishlist
Delivery
Standard Due date unavailable
True colour at the speed of light
Print quickly and vividly with a Samsung CLP-415 Colour Laser Printer. Thanks to Samsung's ReCP technology and new polymerised toner, your printouts will be crisper, more vibrant and more vivid than ever before. And, with print speeds of up to 18 pages a minute, you won't have to wait to see the results. It's even easier to use, thanks to intuitive controls and support software.
  • Enjoy quality printouts every time with ReCP
  • Print vividly thanks to new polymerised toner
  • Boost productivity with superfast performance
  • Get easy control with streamlined operation
Make sharp images and text even sharper
Boost the overall quality and vividness of your output with our unique ReCP (Rendering Engine for Clean Pages). It automatically adds dots along the edges of images and characters, meaning everything looks so much sharper and cleaner. What's more, those white gaps between coloured areas that are so common with other devices are eliminated. What you and your team are left with is an outstanding colour output.
Make colours more vibrant
Polymerized toner is one of our most innovative breakthroughs of recent years. Its revolutionary particles are smaller and more uniform, giving lines extra definition, tones more graduation and colour more impact. Its higher wax content not only improves the image gloss, but also enhances the durability preventing unwanted fading. And as the polymer toner can be applied in a thinner layer with lower fusing temperatures it reduces the paper curl and energy consumption as well.
More power, better productivity
With the power of two cores the device can process your work files simultaneously and therefore with higher speeds. The 256MB memory ensures even heavy printing documents are spooled faster and you don't have to wait long for your print outs. What all this means for you is simple: the CLP-415NW is perfect when there's a lot to print and a tight deadline to meet
An easier user experience for you
Let's face it; your time is too precious to waste standing around a printer for hours on end. So from operation to support software tools, you're in total control with this easy to use small workgroup printer.
Easy Eco Driver
Easy Eco Driver helps you compile digital documents in multiple formats and makes it easy to share them with others - even through social networks
Your reliable business partner
Thanks to the latest technology and high quality components, you'll find the CLP-415NW is as dependable as they come, even during the toughest print jobs.
Cost effective printing with every job
Be in control of your printing cost during the printer's entire time of operation. Low costs per page that keep your running costs low for the time you do business.
Easy Colour Management
The Samsung Easy Colour Manager allows you to adjust the colour balance, saturation, brightness or contrast of any image prior to printing. Perfect for matching the exact colours of your company logo every time.
Remote device control
For maximum control, Easy Printer Manager lets you manage all your devices from one location. Check device and toner status, change device settings or set alerts.
Easy toner replacement
Gone are days of fiddly, dirty and time-consuming toner cartridge changes. It's all made easier with a push loading drawer. What's more, the high yield cartridges mean fewer changes
Mobile Printing
With amazing Samsung Mobile Printing solution, you don't have install any drivers to your mobile devices. Simply Just Install Samsung Mobile Print application on your mobile devices, and you can print directly from your mobile device.
Samsung CLP-415NW - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
16.62 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 18 ppm - colour - A4 (210 x 297 mm) , Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 19 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 19 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution (Colour)
9600 x 600 dpi
USB, Gigabit LAN, Wi-Fi(n)
533 MHz
RAM Installed (Max)
256 MB
Language Simulation
PostScript 3, PCL 6C, SPL (Samsung Printer Language), PCL 5Ce, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, glossy paper, cards, bond paper, recycled paper, cotton paper, thick paper, thin paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
40000 images
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Printer Features
Rendering Engine for Clean Page (ReCP) Technology
UNIX, Linux, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.4 - 10.7
42 cm x 42.6 cm x 26.4 cm
Printer Type
Printer
Print Speed
Wireless
9600 x 600 dpi
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Language Simulation
Printer Features
Media Handling
533 MHz
RAM
RAM Installed (Max)
256 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, Oficio (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
250 sheets
Media Feeders
1 x automatic - 250 sheets , 1 x automatic - 1 sheet
Output Trays Capacity
100 sheets
Duty Cycle
40000 images
Print server
Security Protocols & Features
WPS
1 x USB 2.0 - 4 PIN USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge ( black ) - up to 1000 pages , 1 x toner cartridge ( cyan ) - up to 700 pages , 1 x toner cartridge ( magenta ) - up to 700 pages , 1 x toner cartridge ( yellow ) - up to 700 pages
Power supply - internal
380 Watt
Power Consumption Stand by / Sleep
50 Watt
Sound Emission (Idle)
32 dBA
Sound Emission (Operating)
50 dBA
42 cm
42.6 cm
26.4 cm
16.62 kg
Accessories
£56.26
£61.92
£61.92
£61.92
£14.71
Scroll to top
